Dad and Daughter E30 project
Could be a plugged fuel filter, due to sitting for awhile,Day 7:
Its ALIVE!!
My dad banged on the starter a few times while I was trying to start it and she fired right up!
As you can tell she is having a tough time keeping an idle.. Any thoughts?
Well either way we got her running. Here is my first drive!
Next Problem:
We have this weird whining sound coming from what sounds like the fuel tank area. Is our fuel pump bad?
Well either way we are extremely happy. We bought this car for $600 dollars 16 days ago, have put about $850 into it and have a running car!
do a smoke test It sounds like a vac leak ... get a cigar and blow smoke into the fuel pressure vac line into the intake or the vc vent hose. watch for smokeComment
With the car on get something smoky that you can see in there air and put it around the intake side of the motor. If you see it get sucked into any of the hoses you have a vacuum leak.
Day 8 :
Pics as promised
We started with a lot of cleaning and painting :
Rebuilt Injectors from Maksinjection :
The Head was sent to the machine shop where it received a hot tanking, resurfacing, 3 angle valve job, New valves, cam seals, valve guides, valve stem seals, replacement of the broken rocker and a new rocker shaft
As you can see.. there was some damage when the timing belt broke LOL
Setting up the timing on TDC in preps for timing belt/water pump change :
Its been pretty fun putting this thing back together. Once my dad figures out the fuel pump whine and the idle issues, we will move onto making her look nicer.Comment
I have a question.Look at the OP's first post pic's,look at post pic # 5 at the pre casted tower for the rocker rod closest to the rear. Doesnt it looked stress cracked ? Did you guys get it repaired or get a new head?Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
garage queen 91 bmw 325is / 1972 Chevy El Camino 355 sbc 450hpComment
Oh yeah forgot to post that part. The cylinder head guy welded it up and repaired the stress crack for us. Its the same head that came off it.Comment
My .02, on the intake pic with new injectors, you should clean the gunk on the inside or hopefully did after the pic was taken.
Also, regarding problem, time is ticking on that fuel pump. First sign of it going bad is high whine.Alex 88 m5 | 91 318is | 19 Subaru Ascent
BMW Tool Rentals & Fender RollerComment
