Jntar's 318is budget Turbo build...no longer on a budget :(
  • Schnitzer318is
    • Jan 2008
    • 2057
    #61
    Originally posted by Danny
    Very nice job. I remember hating myself when I did megasquirt on my M42 turbo car. That was a long time ago and it looks like things have developed nicely since then.
    That MS1 is still kicking strong and running great on 10psi... ;)
    Originally posted by jntar
    Thanks! It has quite a bit more to go, but it's getting there. Your turbo thread was one of the two that sparked my interest in turboing.
    Love seeing all these turbo m42 threads now. Yours is coming along very nicely.
    What's up with the AFR target load settings? Mine is setup as with kpa units on the left, not a load %. Would imagine it would be hard to tune without the exact kpa? Or am I missing something...
    "A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
    91 318is Turbo Sold
    87 325 Daily driver Sold
    06 4.8is X5
    06 Mtec X3
    05 4.4i X5 Sold
    92 325ic Sold & Re-purchased
    90 325i Sold
    97 328is Sold
    01 323ci Sold
    92 325i Sold
    83 528e Totaled
    98 328i Sold
    93 325i Sold
    • jntar
      • 459
      #62
      It's 7kpa per 1lbs of boost. So 170% is 10psi. Same thing, just renamed :)
      M42 turbo build.
      http://www.r3vlimited.com/board/showthread.php?t=301330
      • Steve547i
        • 130
        #63
        Great thread. Keep up the good work.
        • jntar
          • 459
          #64
          Thanks!
          Update, got rid of the afm finally. Idles perfect with the ICV intact. I am now having a USB signal issue while trying to road tune. Going to try and run a ground to the USB shield to see if that will help out.
          M42 turbo build.
          • jntar
            • 459
            #65
            On another note...
            Pulled an S54 out of friends m3. Worked on finishing up friends duel webber installed 2002. About to start installing that s54 into an e36 m3.
            M42 turbo build.
            • jntar
              • 459
              #66
              It's time to address the headgasket, head studs, clutch and flywheel. Found multiple leaks in the process.
              Where I got before I decided to call it a night.
              M42 turbo build.
              • jntar
                • 459
                #67
                Got the new clutch/flywheel, head gasket, and head studs on. Noticed that my front timing profile gasket is leaking pretty bad. Time to pull it back apart and correct.
                M42 turbo build.
                • jntar
                  • 459
                  #68
                  And I officially hate the profile gasket...lets hope third times a charm :(
                  M42 turbo build.
                  • Schnitzer318is
                    • Jan 2008
                    • 2057
                    #69
                    I've heard, and read, it can be a real PITA. I'm not in any hurry to do one on mine. *crosses fingers*
                    Good luck on your next attempt being the last one.
                    91 318is Turbo Sold
                    06 4.8is X5
                    06 Mtec X3
                    05 4.4i X5 Sold
                    90 325i Sold
                    97 328is Sold
                    01 323ci Sold
                    92 325i Sold
                    83 528e Totaled
                    98 328i Sold
                    93 325i Sold
                    • jntar
                      • 459
                      #70
                      Yeah it's not fun. Hopefully this is the last time.
                      On another note I've got an electrical issue. Car starts, but windows, a/c blower and aux fan don't. Thinking pinched reverse switch or I wired up my m20 starter wrong.
                      M42 turbo build.
                      • BUDNUNTA
                        • Apr 2005
                        • 996
                        #71
                        Starter wiring or under loader relay
                        We're out there in here.
                        • jntar
                          • 459
                          #72
                          Yep, just trying to track down where the short is. Only 2 things were touched during this. Starter and reverse switch. Ive triple checked the starter. It matches both m42 and m20 bentley manuals. I'm using a late model bosch rebuilt starter so there shouldnt be any wiring differences internally.
                          M42 turbo build.
                          • beardoweir
                            • Dec 2012
                            • 28
                            #73
                            Any updates!?
                            • jntar
                              • 459
                              #74
                              Ended up not using the smallest connection post on the m20 starter. Everything works now.
                              Took a trip to Dallas in the car for Easter and on the way back the car started making a loud rattle on decel and above 2500rpm. I haven't touched the car, it's been sitting. Either something in the timing chain guides is messed up or the cam tray is loose.
                              M42 turbo build.
                              • Schnitzer318is
                                • Jan 2008
                                • 2057
                                #75
                                Why did you got with an m20 vs m42 starter out of curiosity?
                                91 318is Turbo Sold
                                06 4.8is X5
                                06 Mtec X3
                                05 4.4i X5 Sold
                                90 325i Sold
                                97 328is Sold
                                01 323ci Sold
                                92 325i Sold
                                83 528e Totaled
                                98 328i Sold
                                93 325i Sold
