Alright, just placed an order for the Siemens 80lb (835cc) injectors which are brand new for under $300 AND the Myster-E Performance Head w/ 1mm oversized valved, welded jackets, beehive valve springs and 280/274 cam with some additional special work from Shant :)
Turbo M20 Stroker (3.2L) into an E21!(with pics) - Build/Help Thread
Decided to go the MM style route for rods and pistons. 85mm pistons, 134.5mm rod, 21mm wrist pin, flat faced moly compression rings, oil rings. Custom ordered from Carillo.
UPDATE: Also got a T4 GT40r, Tial WG and BOV.Last edited by HaloArchive; 10-24-2013, 03:00 PM.
Got VEMS 3.6 with all modules and everything for a good price with wiring harness. PnP.
Only things left parts wise is an intercooler, manifold, methanol setup and a fuel pump and some ARP hardware.Last edited by HaloArchive; 10-24-2013, 03:00 PM.
I wonder if rev shift is still making manifolds. Also i been thinking of not using the Bosch 044 pump i bought and converting to an in tank and using that AEM e85 pumpLast edited by einstein57; 10-24-2013, 03:49 PM.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
Originally posted by einstein57 View PostI wonder if rev shift is still making manifolds. Also i been thinking of not using the Bosch 044 pump i bought and converting to an in tank and using that AEM e85 pump
Alright guys, here are some pics since I haven't posted any yet. Yes, this is a serious build!
On top of that, I have changed my original plan and it will now be a "3.2l" m20 turbo.
The car
4cyl out
6cyl in
There are more pics ill add them slowly as things go on.Last edited by HaloArchive; 01-25-2015, 11:56 AM.
Watching your thread as well! Keep up the good work!!Originally posted by LJ851kingston is the play by play announcer for this thread.
Originally posted by unloadedak#teamross
bump any updates?318iS Track Rat :nice: www.drive4corners.com
Nice progress. I am currently dailying my M20b31 (86mm bore s52 crank). Once I get my other e30 back I plan to start the turbo build. Want to make it turbo'd to www.drive4corners.com this year!
What are your end goals for it? Driver car?318iS Track Rat :nice: www.drive4corners.com
