In my attempt to clean the manifold today, I put it in our giant blaster at work. Its like a sand blaster but with a different kind of shot that really cleans up parts.
After taking it out, I found something real bad
![](http://i79.photobucket.com/albums/j127/mitchlevy7/Facebook/e30/20160809_194050_zpsaryuko7t.jpg)
![](http://i79.photobucket.com/albums/j127/mitchlevy7/Facebook/e30/20160809_194054_zpsyelkzipn.jpg)
![](http://i79.photobucket.com/albums/j127/mitchlevy7/Facebook/e30/20160809_194101_zpskmxnwkus.jpg)
Turns out one of the runners was cracked at the collector. Its cracked all the way around and I would have to completely take apart the manifold to fix it. Also, the t4 flange was warped. The guy who built it welded studs in, so I would have to cut the studs off, sand it flat and redrill the t4 pattern in. He also mig welded some of the holes from his crappy welding shut and didnt use any filler metal on the runners, hence the cracking. 500 bucks down the drain. Bought the thing like 5 years ago so I don't think I can get my money back.
Good news is I got my first chance to weld sch 10 piping. Got a few good beads down.
![](http://i79.photobucket.com/albums/j127/mitchlevy7/Facebook/e30/20160809_194122_zpssipyex5s.jpg)
Going to continue to use the piece to practice welding. Sch 10. SS is expensive, so why waste it?
Most likely going with a RSI/Good and tight manifold at this point. Its proven itself. This means I can't put the motor in until I save up enough to buy the new manifold. Also means I need to modify the downpipe, which needed a new v-band anyways as I warped the last one.
