Sterling 1990 325is *Turbo Build*
  • ser1992
    • Feb 2013
    • 482
    #46
    MegaSquirt from Whodwho installed today. went smooth and started right up. getting the vacuum line through the firewall was a bit of a betch, but i just poked a hole through the big grommet around the main harness and shoved it though.
    • Chilezen
      • Dec 2013
      • 1892
      #47
      Nice touch with the water temp gauge.
      SWEET
      Currently building a badass coffee table
      Random stuff on insta @kevanromero
      • ser1992
        • Feb 2013
        • 482
        #48
        I got my Condor solid motor and transmission mounts installed and have a question.. I was expecting the "buzz" vibration (which i got with the motor mounts) but the transmission mounts are giving me a "wamp wamp wamp" almost "out of balance" rumble. Is this normal?
        also, when i installed the tranny mounts I bolted the transmission brace back up to where i had sen it was tightened before then put in the mounts and lowered the transmission on top then tightened the mounts. Was that the correct order?
        • Earendil
          • 1662
          #49
          Does the womp-womp happen at idle or while the car is moving?
          I have the condor motor mounts but not the transmission mounts, but I would expect additional MVH when the car is moving, not while at idle.
          Edit: Idle with the clutch in, where nothing in the transmission is spinning. At idle with the clutch out and the car in neutral you'll have half the transmission spinning and I would expect something there.
          1989 - E30 - M20B25 - Manual. Approx 300,000+ miles - Track Rat & Weekend Fun
          2000 - E46 - M52TUB28 - Manual. Approx 130,000 miles - [not so] Daily Driver
          I'm looking for a Lachssilber Passenger Fender and Hood. PM if you have one or both to sell!
          • ser1992
            • Feb 2013
            • 482
            #50
            its all fine at idle. As I accelerate, it build up and almost starts sounding like a Subaru haha its not REALLY extreme, but its really noticeable. Im ok with it but I just want to make sure something isnt going to break.
            • ser1992
              • Feb 2013
              • 482
              #51
              today was a good day to check the mail...
              • ser1992
                • Feb 2013
                • 482
                #52
                now if anyone has a flap for the Zender Evo wing... pm me =)
                • Link
                  • May 2012
                  • 834
                  #53
                  Look forward to seeing the wing on a regular coupe. Good build so far.
                  View my build thread. http://www.r3vlimited.com/board/showthread.php?t=287724
                  • ak-
                    • 12422
                    #54
                    bump
                    1991 325iS turbo
                    • ser1992
                      • Feb 2013
                      • 482
                      #55
                      *Update* I have a shitload of parts and have decided to go all in and do a full motor build instead of just the head.
                      the next couple of months will be exciting... and expensive.
                      • ser1992
                        • Feb 2013
                        • 482
                        #56
