Daily Fail
  • arthb7
    • May 2012
    • 329
    Daily Fail
    About 4 months ago I decided to get a daily e30 so I could work on my project e30. Well that plan failed when I started to fix little things.
    When I just got it
    The car was running a little rough so I decided to look for some air leaks. Found that the intake manifold had air leak. So I pulled it off and decided to clean and paint
    This was the antifreeze
    I had an extra steering wheel laying around and saw a forum member instal a cover which made it look much nicer. I did the same thing. Its a fun little project
    Finally cleaned the intake
    Found some Reps that looked decent. Lets agree to disagree
    Started doing some painting
    My brother picked up this gem to use as his daily. It didn't run at the moment but we got it running. It was a californian car minimum rust.
    After working on the car for about a month I had a great idea swapping it from Auto to Manual transmission.
    At the same time I decided that my ultimate project Henna had to start at some point so I pulled the engine and transmission out. I'm doing a complete restore on Henna with taking everything apart then sticking an m50. Later turbo it.
    For now just taking everything apart
    So after I pulled the engine out of the Grenna I decided well why not give it a paint job.
    Got the injectors rebuilt by a guy from the forum. He did a good job
    I painted the tail lights but could use a nice buff
    Decided to change the rear seal since I'm at it
    Used the clutch and transmission from my Henna car since I will be doing an M50 swap in it I can pick up a different tranny
    new spark plugs
    Tons of little maintenance stuff
    The diff that was in the car was an open 2.97 but I replaced it with an LSD 2.97
    used some fresh oil
    With the new rims the car needed a drop. I got ST springs
    All the shocks were blown so I got KYB shocks.
    I got everything put back together just was lazy to take pictures but I still need to change couple more things.
  • whodwho
    • Jun 2008
    • 1547
    Nice work, should make for a good daily.
    You should change the head bolts out, the hex head ones were know to break the heads off. You can change them out one at a time without pulling the head.
    My M20 Frankenbuild(s)
    4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
    • AwakenNoMore
      • Dec 2010
      • 1291
      Great work so far. Paint Looks great. That jar of coolant is scary O_O
      1991 325i - "Scambles" The Daily Driven lightly modded.
      1988 Mazda RX-7 TII "Mako" The Free Dorito
      bacon by Jared Laabs, on Flickr
      • arthb7
        • May 2012
        • 329
        The headgasket is not leaking what would be the point of changing the bolts?
        • arthb7
          • May 2012
          • 329
          Yeah the paint is pretty good. Still need to buff. plus these are iphone pics I will get some high resolution pics soon.
          The coolent scared too but after flushing the system and putting all new coolent its the right color now. My guess is that the coolent was never flushed.
          • whodwho
            • Jun 2008
            • 1547
            There was an issue with the heads of the hex head bolts breaking off and the head bouncing around like a pinball game, have found a few broken ones and have had to replace a couple cyl heads back in the day from the cam lobe smashing the broken bolt head into the cyl head.
            • DER E30
              • Sep 2013
              • 2347
              Nice! Some kinda nasty soup you had for coolant!
              Forgive my ignorance but what kind of bumper is on the Henna?
              -Christian
              • arthb7
                • May 2012
                • 329
                Haven't heard of that before but would be a good idea to change them out. Do I just replace them for the same OEM ones or get some other kind?
                Thanks
                • arthb7
                  • May 2012
                  • 329
                  That soup did the job for a while! lol
                  Henna has the euro bumpers!
                  • arthb7
                    • May 2012
                    • 329
                    A little update.
                    I tried to get alignment done since I swapped the steering rack for one that didn't leak and I was told I had one control arm bent so I replaced both with new Bavarianauto control arms and used Revshift lolipop bushings
                    Put some Eurogrills in and Kopi smoked turnsignals still need to paint the rubber plastic
                    My cuzin had the front sway bar from a convertible laying around so I got it from him. Its much beefier then regular eta
                    Did some cleaning too
                    It snowed a week ago so I took a picture
                    • Nick_S
                      • Apr 2011
                      • 3655
                      Doing some nice work! Car should be awesome once it's "done".
                      91 318is M50 swapped
                      05 Honda Pilot
                      24V swap thread
                      • D-rock
                        • 714
                        Nice keep it up!
                        -Derek
                        • TheNorthBest
                          • Dec 2013
                          • 20
                          Sub'd. I'm over in Normandy Park / Des Moines area if you ever need another hand!
                          • arthb7
                            • May 2012
                            • 329
                            Thanks I will keep that in mind. Most of the heavy lifting has been dealt with. Now just playing with the little things.
                            • Bglad
                              • Jul 2010
                              • 562
                              What are the specs on the reps, and what size tire did you end up going with? I was thinking about picking up a set.
