Svetlana gets M power. My 91 318is s52 swap (Engine Out) )
OK SO FAR I HAVE OBTAINED
98 M3 s52 with 158,xxx w/ wiring harness and comps
zf transmission
3.23 lsd with no flanges
mz3 diff cover
e34 oil pan stuff
Flywheel clutch
Condor mounts
Send DME to have EWS removed
AND I NEED
driveshaft (would any m3 drive shaft work?)
16" spal fan
Rewire harness for e30.
make engine bay nice nice.
MORE MONEY
other stuff
5-13-14 M42 Is OUT
This is svetlana waiting for m power
this was before i put the other m42 in it and still had my hub caps.. >:(
Svetlana gets M power. My 91 318is s52 swap (NO PROGRESS YET)
My pile of parts
Took my wiring harness off to remove the auto transmission wires
Was left with these 4 abs related wires
Cut off my x20
Labeled the wires with the corresponding pins and crimped new connectors on them so i can put them in the c101 connector i bought from bmw with the pins
Been slowly preping the engine takin bits and pieces off cleaning the block and whatever else i can. Turns out the right engine mount arm was cracked so i gotta get a new one of those.
