1986 328 stroker turbo
  • boosteddirty
    • Jan 2014
    • 61
    Welcome to my first build thread.
    I am going to start off very easy and quick. Sorry for the lack of photos and professionalism.
    I found an e30 off ebay for $750 in philly. It was in rough shape. The paint was dull and the m20 was shot.
    Welcome to the family ;) looks good in the rain!
    The best part about her is the interior, immaculate. No tears in the leather and no cracks on the dash.
    I started prepping the engine bay, pulled the m20, wiring harness, and cleaned and painted the bay. Then taped up the bay with DEI. I will eventually shave the engine bay.
    Pulled the m50 out of an e34.
    Time to tear it apart. Sucked that I didn't take enough photos of the teardown, I was distracted so many times.
    Dipped the block and painted.
    The assembly begins.
    8:5.1 wiseco pistons with Eagle H neam rod
    2.8 crank
    ARP 2000 head studs. Main cap bolts and bearing have been replaced(not pictured)
    Stock head all clean, torqued, and ready. Reused the cometic mls headgasket. Coating was in good shape. And it held pressure.
    The swap begins!
    Yeah! the parts has arrived. Precision 6262, Bluntech manifold, and of course the Miller WAR chip. Also got these neck destroyers CCW LM20. 16x9 et 30 rear 16x8 et30 fronts. 215/40/16 stretched tires. and BC racing coilovers. Treadstone performance intercooler, pipes, t bolt clamps and silicone bends. Also found a perfect lip at a junkyard.
    51mm Tial bov and 38 mm Tial mvs wastegate
    Pick this bad boy up! Lincoln electric 140 mig. Im not a pro. :-\
    Turbo, manifolds and AKG wiring harness adaptor are hooked up. One problem is the m42 radiator. Im not sure if it provides sufficient amount of coolant for the system.
    Zf m3 tranny filled with purple blood. Utilizing the oem dual mass flywheel to hold boost. Also got an oem exedy clutch and pressure plate (not pictured).
    Made a double gauge panel with switches. Surprised how flush it turned out. Hooked up the boost gauge and the innovate mtxl wideband. Switches is for the fan, fuel pump, and an open-source. Last knob is the WAR chip.
    3" mandrel exhaust all the way. Wrapped downpipe. Total of 5 vband clamps. Dynatech muffler. Open wastegate dump. Sorry im not a professional welder. Its my first time welding stuff.
    Paint job failure due to a lack or thinner.. then I fail again with maaco. Ill deal with paint after im done with the build.
    MAACO
    SH#t happens again!!! It started to blow white smoke after 500 miles during the break in. I took off the 3rd spark plug and found coolant inside! Took the head off and found out there was a crack! There goes more cash. I purchased a very clean, well conditioned head along with a.075 mls cometic gasket. I had to visit VAC motorsports to pick it up. And its all fixed.
    Old e30 fuel tank was busted and fuel lines were corroded. See pic of me on the side of the road fixing a fuel leak. I was headed towards the tri state tuners show but decided to turn around. The fuel system overhaul begins. Custom -10 fuel rail, Miller blow thru MAF, 42lb lucas injectors, -10 fittings and braided fuel lines, aeromotive fuel pressure regulator, aeromotive a1000 pump, aeromotive filter, 20 gallon fuel cell (without a sending unit...idiot >:( ). Vacuum lines are braided stainless steel lines. Drilled the valve cover for ccv. Oil catch can from jegs. All the braided lines and fittings are made by JEGS. I thought the wiring harness cover for e30`s were extinct but thankfully ESC tuning had them in stock. Last but not least is a tune. The wastegate is safely set at 10psi. Hopefully it puts out a high horsepower rating. I know I went through it so quickly. I will keep you guys updated on this build. Thanks for watching.
    1986 328 M50 stroker turbo, Precision 6262, Miller tuned, Aeromotive a1000, 8.5.1 Wiseco pistons, Eagle rods, Tial wastegate @20lbs, Tial bov.
    Instagram @e30_fred
  • Peattie
    • Apr 2013
    • 260
    Very nice. I'm interested in seeing how much power this thing puts down.
    • stanhayward
      • Mar 2013
      • 765
      Damn that's a wicked set up
      1990 325i Touring - The Bonsai Bimmer - Patiently Waiting
      1984 316 Coupe - The Base Model - Pain in the Ass
      1988 750iL - The Daily Driver
      ...And a couple others...
      • sayed ali
        • 762
        Great job
        M20B28 Turbo
        My Build Thread
        http://www.r3vlimited.com/board/showthread.php?t=255839
        • boosteddirty
          • Jan 2014
          • 61
          UPDATES
          Replaced the -10an fuel rail with a -8an rally road fuel rail. Also replaced the 42lb injectors with 60lb semens injectors. Now it runs a lot smoother.
          Instagram @e30_fred
          • JCarp90
            • Feb 2011
            • 1759
            My car also got so much smoother when I yanked out the Bosch injectors and went with the Siemens Deka 60#ers. Badass build!
            • .FUDD.
              • Feb 2013
              • 154
              Awesome Build ! I started following you on IG @that_harshman. Lets se some dyno #
              1993 E30 Vert/Turbo/MS/Borbet BS
              Originally posted by anabolice30
              Oh well, not like I could scoop any of the chicks in this thread. My e30 is still on bottlecaps..
              • itskingsteelo
                • Jul 2013
                • 1340
                Fuckin amazing build.
                Originally posted by dvck
                • dunebuggyjay
                  • Nov 2011
                  • 257
                  Great build!
                  What treadstone intercooler did you use? How much modification did you have to do to fit it?
                  Thanks
                  Jay
                  • redsubdivisions
                    • Feb 2011
                    • 1762
                    Nice build! once I'm bored with my M20 turbo, I plan to go M5x turbo myself. Props, sir.
                    1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
                    2012 Passat TDI - DD Duty
                    2008 GMC Yukon XL Denali - Kiddie hauler/grocery getter
                    • E30NJ
                      • Aug 2013
                      • 921
                      Wow what a turnaround for a e30. nice to see.
