Went to bleed cooling system and drive it for first time but that did not happen... Started bleeding cooling system and once the car hit operating temp it immediately started to overheat. It was pumping coolant out of the expansion tank and continued to over heat every time after, I didn't let it get hot though I shut her down the second the needle got pass center. Also my fan that I wired in isnt kicking on at temp, I'm wondering if my thermostat isn't working. I cant continue to try and bleed the cooling system if it just overheats so i cant try and work any more air out until it rest at operating temp. What i don't get is all this stuff worked perfectly before I rebuilt motor. My car is also bogging down if i tap the throttle.
