Daytonaviolett Sturmwagen E30
  • Thujalvi
    • Oct 2012
    • 72
    Good afternoon, I am mostly a lurker, and while my car may not be particularly interesting in and of it's self, I figured my stumblings across the project car minefield might be amusing to some of you, so I give you the short story of my E30, along with the normal project thread bits.
    Sturmpanzer E30 by Thujalvi, on Flickr
    So everything begins in the summer of 2012 when I'm presented with a chance to buy this car, a 1993 316i touring in Daytonaviolett metallic with absolutely no options, and before you ask, no, sports seats, power steering, sunroof, or fog-lights weren't optional on there design edition cars.
    Cabin by Thujalvi, on Flickr
    Good points on the car were that almost everything worked, apart from the blower motor and fog-lights, but neither of them was a big deal. What was a big deal was everything else. Beat-up paint, tatty interior, wrong size tyres, general neglect and a plethora of GDPO stuff meant that the car was pretty much a project from the word go, and as the M40 is a timingbelt motor, that was the first thing to get done.
    Devilry by Thujalvi, on Flickr
    And that of course is a gloriously simple operation, you only need to dismantle the cooling system and the entire front of the engine, as well as replace the water pump, but that was going out anyway. Following this over time I fixed all the little electrical niggles and got another set of wheels to go with the style 5 ones, which soon got put on winter duty. It was essentially trouble-free motor for a while.
    Until an anonymous cyclist decided that he didn't like the car, and after evasive maneuvers, a big bang and a lot of fuel later this happened:
    2012-10-09 17.10.33 by Thujalvi, on Flickr
    2012-10-09 20.42.10 by Thujalvi, on Flickr
    Right in the face by Thujalvi, on Flickr
    So I had to evade/not hit the fucker, and instead I ran into a traffic divider and a traffic sign, resulting in a gaping hole in the floor and a ruptured fuel tank.
    Welds by Thujalvi, on Flickr
    No matter, I'll just weld the floor back together and put in a brand new fuel tank, right after plotting to hunt down the fucker and stabbing him to death.
    I kid, I kid. But it was quite expensive operation, and meant I was without wheels for two weeks of so. After that came winter, and only trouble was a distinct lack of traction, but all the sideways business more than made up for it.
    Come spring 2013 all was well, I was slowly improving things, hoarding parts and enjoying the car, and at this point I was starting to contemplate an M5x swap as well, like you do when you have such an anemic engine as the M40B16.
    Then, in June I went on a bit of a roadtrip with a bunch of friends, and things went downhill fast.
    Sturmpanzer by Thujalvi, on Flickr
    Driving through the backroads of south-eastern Finland, we were hit with a thunderstorm, and not long after I lost all power, and the engine wouldn't start. At first I though it would have been an electrical problem, and that I could carry on after fixing something innocuous and simple, but no such luck.
    Timingbelt catastrophe by Thujalvi, on Flickr
    No such luck at all. After getting the car towed and trailered back home, diagnosing the problem began, and very soon it turned out that the timingbelt tensioner had shat itself.
    Tensioner by Thujalvi, on Flickr
    Valves by Thujalvi, on Flickr
    The bolt had snapped, and the exhaust valve on cylinder two shook hands with the piston, turning the engine into a boat anchor. Though the damage may not appear visible, it wouldn't keep compression, and a valve job would have cost more than another engine of the same kind.
    Now at this point I was pretty much set on a six cylinder, having driven a friend's 325i, and was unanimously told to sell the old one and just buy a car with a six already in it, but these people weren't car people, they weren't petrolheads. While I was told to not fall in love with a car, and objectively one really shouldn't, it was already too late, I'd be keeping this one. As I mentioned about the hoarding parts, a lot of it had been towards an M50/52 swap, and this was something that was about to pay off. You see, I ran some numbers and looked at what a 325i with a body as good as this one would cost, and quickly concluded that it'd be cheaper to swap in an engine like the one seen here.
    M52B25TU by Thujalvi, on Flickr
    I ended paying about the same for the engine and gearbox as did for the car a year earlier, which wasn't very much, 500€ for the car, 550€ for the motor and transmission. Had I gone for an M50 I'd have a running, driving car by now probably, but I was attracted by the lightness and modernity of the engine, which means that the car sits in the same spot in the same warehouse at this very moment as it does in the picture, which is from last August, a day before I flew to Germany to see the oldtimer GP at the Nürburgring.
    Porsche 904 by Thujalvi, on Flickr
    Upi's 2002 by Thujalvi, on Flickr
    As the winter rolls in, so do the parts, and thanks to the M52TU's undesirability, the budget stays in line. During this time I start talks with DesertBMW/Hakentt about having a DME programmed for the car, while the car starts taking shape. Polyurethane bushings for most places arrive along with Condor Speedshop engine and gearbox mounts, all while the engine itself goes under scrutiny, showing signs of neglect, but not overtly so.
    Oilpan project by Thujalvi, on Flickr
    Soon after the engine is test fitted into the car for the first time.
    M52TU Test Fitting by Thujalvi, on Flickr
    Only to come back out of the car, to have the flywheel and new clutch installed, and be tweaked further all the while I crack on the electrics connecting the engine and car together.
    Wiring by Thujalvi, on Flickr
    M52TU by Thujalvi, on Flickr
    M5 Booster by Thujalvi, on Flickr
    And this brings us to the present, the engine is back in, electrics are about 90% done, and this coming week I'll filling her up with oil, finishing the important bits, and hopefully I'll have a running motor on my hands, though to assume everything's right the first time around would be delusional, I'm expecting to spend at least the whole month ironing out the bugs, but she'll run, eventually.
    Behind the scenes by Thujalvi, on Flickr
    Shift console by Thujalvi, on Flickr
    Shifter rod by Thujalvi, on Flickr
    So if you got a laugh, kicks, schadenfreude, or ideas out of this, or if you have any helpful hints or suggestions, feel free to reply, and if you managed to stay with me to the end, thanks for reading.
    See you on the other side.
    '93 Daytonaviolett Touring Design Edition
  • DER E30
    • Sep 2013
    • 2347
    Kool! Sub'd... Stupid bike riding fools!
    -Christian
    • Thujalvi
      • Oct 2012
      • 72
      So this week I received a 3,73 ratio LSD, which is probably way too short ratio still, but should be more manageable when compared to the 4,27 open diff currently in the car.
      Typ 188 Locker by Thujalvi, on Flickr
      Furthermore, the wiring is done, for now at least assuming everything has been wired correctly, and I've been finding out just how well the M52TU intake manifold fits into the engine bay, which is to say not well at all.
      Still, let's talk performance. The M52TU isn't very popular engine for these swaps for a couple of reasons, one being performance. The 2,5l version that I have is rated at 170hp, and combined with the difficulties set by the software it's not very brilliant, though at least the two stage DISA intake somewhat improves low end torque, and on the whole, the wiring is actually somewhat easier, provided you can get all the connectors (I'm looking at you, x60004.) Still all hope isn't lost, as these engines take the M54 intake manifold, though you do need an adapter plate for the throttle body, but those a readily available, and furthermore, I've been led to understand that these motors also respond rather favourably to exhaust modifications, so all that, with a proper tune has one looking at 190-200 crank horse power with some quite usable torque. Aside all that, this car is getting H&R Sport springs with Sachs M-Technik dampers and the almost mandatory rear shock reinforcement plates and front camber plates, engine and gearbox mounts are Condor ones and most, if not all bushings are going to be polyurethane.
      I'd be interested to hear any experience people might have had with similar suspension setups.
      Thanks.
      • LJ851
        • 7919
        I like it.
        Lorin
        The M30 is God's engine.
        • Thujalvi
          • Oct 2012
          • 72
          Thanks, I really like your Porsche myself.
          • Lake
            • Apr 2013
            • 177
            Awesome!
            Originally posted by Ty13r
            if you scream while doing it you'll gain extra power. worth a try.
            • Farbin Kaiber
              Lil' Puppet
              • 29502
              Originally posted by LJ851
              I like it.
              • e30austin
                • 15382
                Giggity.
                • JCarp90
                  • Feb 2011
                  • 1759
                  Oh helllooooo
                  • CorvallisBMW
                    Long Schlong Longhammer
                    • 13039
                    Very cool. Is the m52TU essentially the same as the m54b30, aside from 500cc less displacement? It looks the same on the outside. You'll really enjoy the added torque from the new motor, it really is fun being able to pull strongly from 2000rpm.
                    • Thujalvi
                      • Oct 2012
                      • 72
                      The biggest differences between the M52TU and M54 is that the latter has an electric gas pedal as well as a slightly different intake manifold, and the b30 has some further modifications over the b22/b25 versions.
                      Here's a bit of something that happened today
                      EDIT: Warning, open headers.
                      • Lake
                        • Apr 2013
                        • 177
                        keep up the good work!
                        • Roysneon
                          • 4505
                          Liked.
                          Originally posted by mbonanni
                          I am a pursit now.
                          • Thujalvi
                            • Oct 2012
                            • 72
                            As it's been over a month since the last time I've updated the status of this project of mine, here's the current state of affairs with the sturmpanzer.
                            I bought an 318is radiator, and am currently waiting for the mounting bits to arrive. Then over the Easter I had the drive shaft shortened by 65mm to fit with the Getrag 220, and it went in beautifully, shame I didn't take any pictures, but between the 220 and the 168 diff (subject to change) it went in without having to fiddle with the center shaft bearing, which was replaced while the whole deal was being cut up as well.
                            First start! by Thujalvi, on Flickr
                            Also I've since cleaned up the wiring.
                            But where I'm currently at is the clutch, which is the one thing that's stopping me from having a somewhat drivable car. While fitting in a proper size slave cylinder and then airing the system, something went pop, and then all my brake fluid was pouring out of the bell housing, causing a resolute "fuck this shit" reaction which brings us to the present.
                            So if anyone has any good ideas on what would cause that, and how to fix it, I'm all ears.
                            And now some further photos not in any chronological order.
                            Enjoy.
                            • Quadrajet
                              • Jul 2008
                              • 1278
                              To answer your clutch "Pop" question. Hopefully, once you pull the slave, you may find the push-rod has either bent or has just plain exited the unit.
                              I once scored a car on the cheap that wouldn't "get out of neutral". Took out the clutch slave, found the rod was bent, crossed my fingers and put a spare from my used parts stash in. Bled the slave.
                              Tested the car on the road an hour later, worked fine and shifted through all the gears. Hopefully it will be that simple for you.
