phenryiv1's 1989 325iC Project - SETA 2.7i Swap Complete and Running!
    I did get a picture of the front valance-
    Now just trying to sort out the list of the seals that I will need for the top.
    Parking this here for me...
    No. Description Part Number Price
    01 Rubber seal 54318100908 $190.98
    02 RAIL FRONT 54311932704 $51.46
    03 Covering left 51721940065 $86.24
    03 Covering right 51721940066 $86.24
    04 RAIL FRONT LEFT 51321922779 $57.34
    04 RAIL FRONT RIGHT 51321922780 $57.34
    05 RAIL CENTER LEFT 51321922781 $53.45
    05 RAIL CENTER RIGHT 51321922782 $53.45
    06 RAIL REAR LEFT 51321922783 $45.28
    06 RAIL REAR RIGHT 51321922784 $45.28
    07 Left rear sealing 51321933563 ENDED
    07 Right rear sealing 51321933564 ENDED
    07 Left rear sealing 51328103193 $92.05
    07 Right rear sealing 51328103194 $92.05
    08 LEFT REAR WINDOW GUIDE 51361923917 $74.06
    08 REAR RIGHT WINDOW GUIDE 51361923918 $74.06
    09 Grille 51131932802 $51.61
    10 Lock left 54311932777 $190.44
    10 Lock right 54311932778 $190.44
    11 COUNTERSUNK HEAD SCREW M6X16-8.8-ZNS3 4 07119904304 $0.25
    11 Torx bolt ISA M6X16 4 54318103110 $0.65
    12 BASE PLATE LEFT 54311942963 $22.57
    12 BASE PLATE RIGHT 54311942964 $22.57
    12 BASE PLATE RIGHT 54312230696 $13.89
    13 COUNTERSUNK HEAD SCREW M6X12 4 52101817063 $0.92
    14 Recessed handle 54311932896 $7.62
    15 Clamp 54311932852 $2.20
    19 Push-button 51131820141 $0.31
    21 Edge protection 54311932890 $18.95
    22 Cover 54311965798 ENDED
    23 GASKET LEFT 51321942793 $12.57
    23 GASKET RIGHT 51321942794 $12.57
    24 Support 54311965883 $26.48
    25 COUNTERSUNK HEAD SCREW M4X10 4 07119904433
    27 COVERING FOR CENTERING BOLT 2 54311971255 $11.74
    Looks like I need at least 1 (maybe 2) each of 51321942793 and 51321942794 to seal between the frame and the top itself.
    Patrick Henry
      Look at what arrived!
      Also got a pair of these from Luke. Not my first choice in subwoofers but they work with the enclosure and the price was right.
      Inner (rubber) shift boot, plus a nutsack...I mean a sack of nuts.
      Lastly, I picked up the nut removers that were missing from my set, plus a set of screw removers. Both were half price.
      Patrick Henry
        Dude.....slow down.
        ________________________1988 528e Rally-xmobile___________________
        2014 WDCR Rally-X MR Season Champion, 2014 NE Div. Challenge MR Winner
          Originally posted by 95maxrider View Post
          Dude.....slow down.
          Do not comprehend "slow."
          Patrick Henry
            A couple shots of how crappy the weatherstripping is...
            Patrick Henry
              So a couple new things.
              Local guy was selling some rare NLA BMW Motorsports replica wheels. They came with brand new A/S Toyo Extensa HP Tires 215-45R17 and are 17x7.5" with an ET of 18 or 20 (need to check). I surely did not need them but I really liked them so I pulled the trigger.
              Alos bought a Z3 antenna for the convertible. I got tired of the fencing foil antenna hitting the garage door when the car was up on the lift, plus it just looked stupid. I have had trouble in the past with the power antenna so the Z3 option seemed like a better route. This came with the grommet, bracket, and a couple optional-length antennas.
              Also, the MTC transmission joint arrived so I can finally get to work on finishing the DSSR install/shifter refresh project.
              Patrick Henry
                Close up of one wheel:
                Patrick Henry
                  ....but why?
                    ....but why?
                    I know how you feel about them. I really like them and always have. Sure, 17" is an overkill on an e30 but I really like them and despite loving the TRM C1s, I don't like them on this car as much as I thought that I would. I will bolt them up and make a decision once I have the rest of the car sorted out. "Correct" 17" wheels for the e30 don't come up often and the proximity, condition, and price all worked out on this set so I impulse-bought them.
                    Patrick Henry
                      I had these on one of my coupes. I think they look great!
                        That's funny i was reading threw your thread and I see a pic of the z3 antenna and i see 2 antennas and I'm like wait a minute....
                        Glad you got that antenna already, keep up the work!
                        1992 e34 Touring- S50 Swap
                        1992 325i-S50 Swap
                        1995 e36 M3 Mugello Red - S50
                        1991
                          Sweet build thread. Glad to hear that the Yellow Speed suspension worked out for you. If you ever need replacement parts, CarShopUSA carries a full range of replacement parts for the Dynamic Pro Sport coilover suspension system.
                            Thank you for the tip. Hopefully I don't need parts but it is good to know where to turn if the need arises.
                            Patrick Henry
                              Nearing top replacement time. The seals shipped and should be here this week.
                              Also received a few oddball parts that I needed- the last of the "waist" trim (rear fender sections), a leather e-brake handle, and a new rear roundel:
                              Also (DRUMROLL) out of nowhere (well, technically Facebook) I saw a semi-local was pulling an M20B27 SuperEta from a chump car build. He was initially offering it for what he called next to nothing (which became $200, then $125) but he had issues removing the motor. I offered to help out and he gave me the motor in exchange.
                              I had a spare B25 that I was going to use for spare parts (mostly sensors and stuff) for the rallycar but with the rallycar gone I had put up for local sale. Since I picked up this motor I will be doing another (http://www.r3vlimited.com/board/show...=155221&page=6) 2.7i build with the B25 and this motor. This is one time that an item not selling is a good thing.
                              This car seems to have a really bad oil lean and if I was going to refresh the timing belt and seals, I was going to do it right and rebuild the head on my spare motor to expedite the process. Now having found a bottom end as well (and a more advantageous one at that) this could end up being a better outcome that I had initially envisioned.
                              Need to do this:
                              http://www.gress.org/home/cars/track...down%20DIY.htm
                              Patrick Henry
                                Hopefully the last "hey look I got parts" post for a while. With the arrival of these last seals I can move forward with the install if the top.
                                Now I just have to get the transmission/selector rod setup assembled so that I can drive to the shop. While I am not opposed to DIY projects, I just lack the time and patience to do the top install.
                                Patrick Henry
