"Dirty Thirty" 1987 325is M20B25 Turbo Build
  • AbsorbantNut
    Non faccio funzionare questa merda
    • Jun 2010
    • 2491
    Lookin' good Maison
    Did you get an OEM BMW head gasket or an oem replacement like victor reinz or gotez?
    '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
    • Maison@Forge
      • Mar 2014
      • 19
      Originally posted by Overlord475
      I have a spare 885 head that is currently half disassembled. (Valves and springs are still in)
      PM me.
      Thank you for the offer. I will know for sure if I have a head on Friday when the seller gets back to me. If that somehow falls through, I will PM first thing.
      • Maison@Forge
        • Mar 2014
        • 19
        Originally posted by AbsorbantNut
        Lookin' good Maison
        I got the OEM gasket. MLS has a head gasket designed better for use with forced induction, however it was pricey. I figured the OEM head gasket would be sufficient enough with the ARP head studs. Hopefully the head gasket won't slip and block a coolant jacket.
        • AbsorbantNut
          • Jun 2010
          • 2491
          Okay, cool. I was gonna say beware of the victor reinz ones. They are prone to leaking. Yea, MLS is cool, John@wottech in Ft Lauderdale is a dealer if you want to upgrade to one later;) Also, you could've gone full Condor with the bushings instead of poly:p The OEM one works fine with a good tune....which you will have with MS. Such excite
            • 37834
            PM me and we can go from there!
            Why not share the info with all of us?
            Grover Beach, California
            BimmerHeads.com
            • Maison@Forge
              • Mar 2014
              • 19
              Brake lines aren't available until I get a set measured out, which will be this weekend hopefully. After that, free for all! I've no issue sharing anything!
              • Maison@Forge
                • Mar 2014
                • 19
                OP updated :D
                • Maison@Forge
                  • Mar 2014
                  • 19
                  OP updated. Also, looking for the rear plastic bumper and "is" side skirts!
