'90 325i Project Log… continued
  • jd_e30
    • Mar 2014
    • 167
    Got around to adjusting the throttle cable last night. Preliminary adjustment was 5/16" but ended up at 1/4"
    1990 325i
    • jd_e30
      • Mar 2014
      • 167
      Car is driving nicely. I still think there is power left on the table somewhere, but not sure where yet.
      There are definitely a few pressing issues that I need to take care of.
      -Engine oil is dripping from somewhere - hopefully just needs a new crush washer
      -Power steering is leaking and seems dirty. I will change this fluid and inspect for leak
      -fuel hose needs replaced (waiting for it to arrive)
      -valve adjustment (don't know when the last one was done)
      But I REALLY want to track down this incredibly annoying/seemingly rear-end related whining/scraping noise. Given Ethan's long list of everything recently done (below), I really am not sure what this noise could be. The noise gets louder with vehicle speed, but does not change with engine RPM's, or go away when engine is turned off with the car still rolling. I plan to lift up the rear end and do some inspecting tomorrow. I've searched the forums and Google endlessly, but can't find any possible culprits outside of things that were already replaced by Ethan (bearings/csb/giubo/diff/bushings).
      CV Axle(s)?
      Ujoint?
      What am I missing?
      - valve cover/valve cover gasket
      - intake manifold/gaskets
      - bitch tube o-ring
      - timing belt/water pump
      - OEM head gasket and head bolts, head checked, valves/pistons cleaned
      - rebuilt M50 17lb injectors
      - new spark plugs
      - freshly powdercoated rear subframe, all new bushings and hardware
      - freshly powdercoated trailing arms, all new bushings and hardware
      - new rear wheel bearings, parking brake shoes and hardware
      - new brake rotors and pads
      - new ebrake cables
      - rear brake soft and hard lines w/ATE super blue
      - rebuilt 3.73S rear dif with new bushing
      - new guibo/CSB
      - trans mounts
      1990 325i
      • Lake
        • Apr 2013
        • 177
        Keep up the good work!
        Originally posted by Ty13r
        if you scream while doing it you'll gain extra power. worth a try.
        • Graebmw95
          • Mar 2014
          • 362
          Hey man! Love the car! You should definitely join the Colorado BMW Groupë on facebook!
          I also love in Parker and i totally thought your pictures looked familiar. Haha but heres my baby!
          Maybe we could go cruising some time!? Good luck with the car man! Names Noah~
          • jd_e30
            • Mar 2014
            • 167
            Hey man! Nice to meet you. Your car looks great! I'd love to meet up with some local guys. I plan to attend a few cars n coffee meets soon too.
            1990 325i
            • roznic
              • Mar 2013
              • 2876
              wow, that's one clean e30!! Good luck with it
              • jd_e30
                • Mar 2014
                • 167
                Thanks!
                Well, quick update on the e30. I checked out rear brakes and both sides were rubbing pretty badly on the parking brakes- more so on driver side. I adjusted them and the cables and everything is great now brake-wise. Car also feels quicker without the constant drag of the parking brakes.
                Unfortunately, this did not cure the whining noise I am hearing. Any ideas on where to start here? Anyone?
                1990 325i
                • jd_e30
                  • Mar 2014
                  • 167
                  Ok another update. Horrid grinding noise coming from rear end. Something is up with the rear left brakes... I think parking brake. Yikes. Going to tear them down and start at square one
                  1990 325i
                  • jd_e30
                    • Mar 2014
                    • 167
                    Fuel hose and clamps arrived.
                    Rear window "sail" trim piece clips installed
                    Pass side
                    Driver side
                    I also noticed that my parking brake warning light wire (blue) is loose. Trying to figure out how and where this attaches. Anyone know?
                    1990 325i
                    • jd_e30
                      • Mar 2014
                      • 167
                      Got the the new fuel hose installed. Excited to actually be able to fill it up past halfway without a leak.. I hope. It looks like the outlet on the gas tank has some rust but hopefully it hasn't rusted through. My worry is that it has. We will find out soon.
                      I adjusted both parking brakes to where I want them but unfortunately that did not resolve the buzzing noise I am hearing above ~20mph. I'm starting to wonder if it really is just rear diff noise. I am going to have my mechanic take a look soon. I know that many people have complained about this noise, so hopefully I can shed some light on things when I'm able to put it up on a lift and listen from underneath while the rear wheels are rotating.
                      I have a big order ready to go at Pelican, which is comprised of a lot of maintenance items that I will list later. I hope to have the rear trans and power steering reservoir leaks resolved soon along with fresh fluid in both.
                      I need to get everything sorted prior to the Drive 4 Corners meet.
                      In the meantime, here are some pics of how it sits now...
                      1990 325i
                      • Graebmw95
                        • Mar 2014
                        • 362
                        Sooo excited for four corners ...
                        • jd_e30
                          • Mar 2014
                          • 167
                          Me too!
                          1990 325i
                          • jd_e30
                            • Mar 2014
                            • 167
                            small update on things...
                            I changed the rear diff fluid. I was going to go with Redline but decided on locally available Mobil 1 75w90 synthetic LS. It took about 1.5 qts+. The old fluid was pretty nasty, so I am glad I changed it.
                            The power steering fluid has been leaking up front, so I tore things apart and discovered the issue. The return hose has a worm gear clamp on it, which wasn't leaking. The feed line however had the factory crimp-type clamp and that hose was a mess. It looks like things had been leaking for some time, not to mention the fluid was black. I drained it, degreased everything, and fed the return line into a drain pan while I rotated the steering wheel back and forth countless times while adding fresh dexiii ATF. I did this until fresh fluid was coming out of the return line to ensure that old fluid had completely drained from the steering rack. I buttoned everything back up and no more leak. Pics below.
                            Next up on the list is new trans fluid. Redline MTL should be here on Tuesday. I'm thinking my whining/buzzing/metallic noise might be coming from the transmission, which would not surprise me a bit... I went through 5 transmissions on my chevy traiblazer ss, so it would figure that this is my luck.
                            I'm very excited about how everything is coming together. The car is driving better than ever. Stay tuned for more....
                            Old fluid... yuck!
                            What a mess!
                            All sorted
                            1990 325i
                            • lambo
                              Captain Scene Points
                              • 10953
                              Haha when my power steering started leaking I just decided to delete it...
                              • jd_e30
                                • Mar 2014
                                • 167
                                no power steering!? lol! Can't wait to see how that feels.
                                1990 325i
