'90 325i Project Log… continued
  • jd_e30
    • Mar 2014
    • 167
    #61
    I will!
    My light was not coming on much at all, but then started to come on and stay on every time I drove. I will keep you updated.
    1990 325i
    • HersheySquirts
      • Apr 2014
      • 119
      #62
      Awesome looking car, I have been wanting to find a late model coupe similar to yours for sale near Louisville, but it's been quite a challenge haha. Enjoy your e30!
      • jd_e30
        • Mar 2014
        • 167
        #63
        I'm assuming you are in Louisville, CO? I haven't seen too many e30's for sale locally actually. I occasionally see one on the road. I saw an e30 m3 a few months ago in Lafayette.
        1990 325i
        • HersheySquirts
          • Apr 2014
          • 119
          #64
          Nah Louisville KY, an e30 dead zone...
          • jd_e30
            • Mar 2014
            • 167
            #65
            Good news. Both the coolant and brake light check lights are gone!
            The coolant level sensor was a straight forward swap. However, the brake switch was a little tricky...
            In retrospect, the OE brake switch was probably fine and just needed adjusting. Basically, when the brake pedal is not depressed, the extending rod is pushed into the red collar/switch due to the pressure of the pedal. The red collar holds the rod at a certain distance. Over time the red collar gets pushed in, so the best thing to try before replacing the switch is to pull the red collar out. This brings the rod out as well. It's hard to explain but if you get under and look it is easy to figure out.
            When I first installed the new switch tonight it didn't work. The brake check light was still coming on. Upon further inspection I realized that the red collar had gotten pushed in and the white rod was not making contact with the pedal. This part is definitely not as good quality as the OE Part.
            I pulled the sleeve out (took some force) which allowed the rod to make contact with the brake pedal. This did the trick.
            1990 325i
            • thatphysicsguy
              • Mar 2013
              • 843
              #66
              is that a bit of fuel pump whine I hear in your vid?
              '91 325i
              • jd_e30
                • Mar 2014
                • 167
                #67
                Most likely. I have the carpet and rear seats out right now, so everything is echoing through the cabin like crazy. However I am chasing down a buzzing/whining/metallic noise that is not RPM dependent and is present when car is rolling with engine off.
                Any ideas?
                1990 325i
                • peter321
                  • Jun 2012
                  • 221
                  #68
                  I really like the look of your car. I hope to get a similar height
                  I was thinking of taking my carpets out to clean them as well. How hard was it to reinstall? Thats what Im most worried about.
                  • thatphysicsguy
                    • Mar 2013
                    • 843
                    #69
                    Any ideas?
                    diff noise would be my best guess.
                    '91 325i
                    • jd_e30
                      • Mar 2014
                      • 167
                      #70
                      Thanks! And I will let you know on carpet install, tonight! Removing it wasn't too bad but it was heavy and soaking wet. Definitely worth removing it to clean and find leaks though!
                      My guess too but a low mile diff was used and all new bearings installed by CA Tuned.
                      1990 325i
                      • jd_e30
                        • Mar 2014
                        • 167
                        #71
                        Being a bachelor until Saturday afternoon = Detailing, Home Depot, e30 and Cars & Coffee!
                        I want to get the e30 shined up for this Saturday’s Cars & Coffee. I am lucky enough to live 1 house down from Dylan@SurfCityGarage (formally from Adam’s Polishes), so I stopped by to pick up some of his new products - Surf City Garage’s new Pro Line (http://www.surfcitygarage.com/shop). What you see is non-diluted All purpose cleaner, car wash soap, detail spray, trim dressing and tire dressing. I look forward to the results! A full detail/write-up will happen sometime soon.
                        I then headed to HD for some miscellaneous crap and supplies I plan to use on the e30. I am going to seal the gaps on either side of the back seat frame, where wiring runs from the trunk into the cabin. The water that was leaking from behind the rear window into the trunk was traveling along this wire path into the cabin. I’ll post some pics of this tomorrow!
                        Also, I am really hoping that I can get you guys to help me diagnose this noise. I uploaded a few videos of the buzzing/whining/metallic noise I am hearing. If you listen in the video you can hear a very high pitched, almost inaudible circular saw/turbine jet, dragging kind of noise. This noise persists with engine off and does not change with RPM’s, but does change with engine speed and rear end load. What do you guys think?
                        Engine on
                        Engine off a few seconds into the video
                        1990 325i
                        • jd_e30
                          • Mar 2014
                          • 167
                          #72
                          It was a long night but the interior install was a success. I was up until 2am getting the car ready for this morning's cars and coffee with my buddy Dylan and his new truck.
                          My fingers are still sore, so I will let the pics do the talking for today....
                          It begins
                          1990 325i
                          • jd_e30
                            • Mar 2014
                            • 167
                            #73
                            Priorities have changed. Car is up for sale here:
                            1990 325i
                              • 37829
                              #74
                              Classic BMW Specialists
                              Grover Beach, CA
                              www.BimmerHeads.com
                              • Graebmw95
                                • Mar 2014
                                • 362
                                #75
                                Why?!??!? D:
