Ghetto E30 Auto-x Car (on a poor college kid's budget)
  • totheredline
    • Jun 2013
    • 762
    Well, Ive been on this forum for a while now but haven't had the energy to put together a build thread. I guess it's kinda too late for that as I think Im going to keep my current setup until at least the end of summer.
    Got the car in late October. Limped it all the way home. Had a blown HG and the throwout bearing froze up, which in turn destroyed the pressure plate. The clutch was non existant. Arrived at my house at 12:00 PM and started striping it down immediately.
    I removed the fenders. Totally striped the interior. Replaced rusted sheet metal and POR15'd almost every inch of the damn thing.
    The car: 1991 318is
    Factory 4.10 LSD
    Engine: M42
    - Ported head
    -Reground camshafts
    -VW lifters
    -Oil cooler
    - Volvo fan with manual override switch
    -Aux gauges (oil pressure, temp, voltage, fuel pressure)
    -Fuel kill switch
    -Dual core M20 radiator
    -All new gaskets
    -Straight pipe to magnaflow muffler (not ricey at all. I love it)
    -Ebay Chip
    -Lightened 323i flywheel
    Suspension/ Brakes:
    -Condor M3 offset FCABs
    -ST front bar
    -Ie rear bar
    -Bilstien BTS kit
    -E90 drop hats
    -Race Skids x-brace
    -wiechers front strut brace
    -rear strut brace
    -Solid rear differential bushing
    -Poly RTABs
    -Z3 steering rack
    -All new ball joints/tie rods/endlinks
    -Stoptech drilled and slotted rotors
    -Bavauto SS brake lines
    -EBC pads
    -Autozone reman calipers
    Exterioir:
    -Red IS deck spoiler
    -IS front lip
    -Pop-out rear windows
    Other:
    - AC system delete (incuding evaporator and lines)
    -All sound deadening removed
    -All carpet removed
    -Headliner removed (because it was shitty anyway)
    -Airbag and airbag wiring harness delete.
    -OBC and obc harness delete
    -retractable antenna delte
    -Power steering delete
    -Steering wheel out of an 88 Vert
    Wheels and tires:
    -US weaves (because I have a boner for stock weaves<3<3)
    -Brand new Falken Azines RT-615k's (Im excited to get these badboys mounted)
    Meet my sexy German queen Heidi (yes she needs some paint BUTT)
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG] ^ The car that started my love affair with BMWs. 5-speed swap with automatic 3.46 differentials. OH BABY. She could launch.
    I decided not to swap the motor right off the bat because I really want to learn how to drive the car at the limit with what it has. You know, the better driver mod? car control is everything.
    Not sure what my next move on the build will be after paint. I picked up an M30 B34 with a freshly rebuilt head and an HX40 turbo. So it's very likely Ill be be turboed next year. If I do go that route it will be non intercooled with a low boost setup. 300hp is plenty for me. (for now at least) Not a huge fan of turbo motors but you cant argue with the performance figures per$$$. spent. I still like the idea of a High comp N/A m30B34 with ported head, 290ish cam, B35 valves, and VW 94mm pistons.
    We shall see.
    Ill post more pictures as soon as I get the chance.
    = Heidi 1988 325 -> 335i. 7200rpm built M30
  • totheredline
    • Jun 2013
    • 762
    Well........
    My M42 shit itself after the first night of running hard
    After this short experience I've determined that it is a piece of worthless garbage with a shittily designed timing case.
    M30 swap will be coming sooner than anticipated.
    • matthugie
      • Mar 2004
      • 1810
      Well, that escalated quickly. Looks like a good start, I'll be interested to see what comes out of this.
      88 325is - S52 powered
      Originally posted by King Arthur
      We'll not risk another frontal assault, that rabbit's dynamite!
      • e30jake
        • Feb 2012
        • 855
        I have a 79k mile m42 out of an e36 I would let go of if you wanted to go that route.... Just throwing that out there...
        What it feels like owning an e30:
        88 325 S50 swap in progress
        90 325ix
        • jwal
          • Apr 2014
          • 385
          Oh no! Im sorry...I am working on basically the same project...I hope my m42 doesnt blow up. I really like the lightweight feel up front
          • totheredline
            • Jun 2013
            • 762
            Got a free E36 M42 to throw in the car while I build the M30. Couldn't pass it up. It decent compression but there was quite a bit of gunk buildup in the head and sump.
            Plans for the M30
            -B34 head port matched to B35 manifold
            -B35 dual valve springs.
            -B35 pistons (should give me 9.8ish-1 compression)
            -Used Bavauto headers
            -Free-flowing exhaust with X pipe.
            -IE 284 cam
            -Have no idea what to do as far as engine management. Probably ms1
            All the money that Ive been saving for paint is going towards the new motor. I'm thinking about plastidipping it. We'll see.
            • jwal
              • Apr 2014
              • 385
              What are you doing to the m42 that you are swapping in?
              • freeride53
                • 11972
                Awesome! This car's got a lot of what I want on my car. Needz moar pics tho. How's your guys' season going? ACRC's?
                1983 Peugeot 505 STI
                1992 Volvo 240 Wagon
                • Vivek
                  attention whore/retard/bitch
                  • 6167
                  Did you timing chain jump a tooth?
                  1992 Mauritiusblau Vert
                  2011 Alpinweiss 335is coupe
                  2002 540i/6 Black/Black
                  2003 GSX-R 750 (RIP)
                  • jwal
                    • Apr 2014
                    • 385
                    I believe he broke a sprocket :/
