TehRaydarlover's AWD Lover
  • Nisse Järnet
    • Aug 2013
    • 1221
    #91
    Originally posted by nando
    I don't think the drivetrain loss is 30% - also it's not linear. if you are making 800whp the % decreases quite a bit. it's more like a slope/offset than just a straight percent. most of it is fixed by the drag of the drivetrain (whatever power it takes to rotate everything).
    in any case I think you are on the right track with your calculations. I've read anywhere from 40-20% air volume at room temperature. The less air, the more it will lock, but it can also blow up that seal faster.
    The dyno measured ~80hp loss between the "road" and engine on my ix. (720awhp, 800hp) Not sure if its more or less losses on the E30ix parts though?
    E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
    E30 M50 6 spd 764whp @ 24psi.
    E30 M20 6 spd 675whp.
      • 34844
      #92
      Right, thats only 10%. Thats my point - its not a fixed value, the ix is about 25% at stock power, but if it was still 25% at 800hp you would melt something lol. It wouldn't be that different on a 525ix either.
      I actually plotted it out at one point using a stock ix, mine, and a super high power turbo ix with known bhp and whp losses. At stock power, it takes about 40hp, but if you double the hp input, the drivetrain loss doesn't double..
      • Nisse Järnet
        • Aug 2013
        • 1221
        #93
        Exactly, it would create tons of heat :)
        The car felt "lighter" with the E34 parts actually, less strain when parking etc. It feels more like my rwd E30 than the stock ix for some reason.
        • boogle2
          • Dec 2014
          • 115
          #94
          I will be disassembling my two transfer cases in a couple months here.... this is some great info.
          Rob
          2011 335i xDrive Msport - sold
          2002 M5
          '88 325ix turbo build :D
          • driftxsequence
            • Apr 2015
            • 203
            #95
            Wow this is awesome! I love the rebuildable VC idea. I hope it works out. How long do you think it took to rebuild the rear differential? It appears to be a weekend job in itself.
            325IX Build Thread
            RX7 Build Thread
            • TehRaydarlover
              • Mar 2013
              • 544
              #96
              Thanks! Yeah it was definitely a good weekend task, or more depending on how anal you are haha. After taking with Jim at MM a few times he suggested I tighten up my backlash to 0.003". I might try to adjust it a little more before I install it, I'll have plenty of time before the car is road worthy lol.
              Build Thread
              Rear Diff Rebuild
              Rebuildable Viscous Coupling
              Transfer Case Rebuild
              "Life is simpler with 12 valves"
              • TehRaydarlover
                • Mar 2013
                • 544
                #97
                So I'm trying to work out my brakes... and could use some advice
                Things I'm trying to decide on:
                - How far away the caliper should be from the wheel. Leave more room for different wheel options?
                - How far can I move the caliper before the rotor hat and adapter bracket offset is enough to cause an undesirable torque during braking?
                - Do I even need to be worried about this torque?
                The two calipers I have modeled are the Wilwood Forged SL6R (left) and the Wilwood Forged Narrow SL6R (right)
                The narrow version is about $75 more a corner, not sure if its worth the price difference, but if the offsets and clearance are an issue the narrow version should be better.
                Any help would be greatly appreciated!! :)
Name:	Brake Adapters Model.jpg
                EDIT: I'll get back to this later, but thanks to Northern for the help!!! http://www.r3vlimited.com/board/showthread.php?t=391821
                Build Thread
                Rear Diff Rebuild
                • TehRaydarlover
                  • Mar 2013
                  • 544
                  #98
                  So here is the T-case rebuild, I actually rebuild it back in January so the details are kind of foggy. If I missed something let me know! Thanks :)
                  Here is the list of parts I used:
                  27111224629 Qty(1) Transfer Case Breather Valve
                  27111224677 Qty(1) Transfer Case Gasket
                  07119981063 Qty(1) 8-BEARING-IX
                  27211224637 Qty(1) 8-NEEDLE CAGE
                  07119981047 Qty(1) Transfer Case Bearing
                  27211224636 Qty(1) Transfer Case Seal
                  27241224660 Qty(2) Front Transfer Case Output Seal
                  07119981724 Qty(2) 8-BEARING-IX
                  27211224632 Qty(1) Drive Shaft Seal
                  27211224634 Qty(1) Collar Nut
                  27241224662 Qty(1) Snap Ring
                  23711130502 Qty(1) Rubber Mount
                  07119963308 Qty(1) Gasket Ring
                  27111226467 Qty(1) Screw Plug
                  A few of these items are NLA from BMW, such as some of the bearings, but you can still order them online from companies like Motion Industries.
                  You will also need a new or good used viscous coupling, see my rebuild a few pages back.
                  So first things first: Disassembly
                  I removed the rear output shaft nut, then used a large 3 jaw puller to pull off the output flange. There's a sealant used between the shaft and output flange that can make removal a little difficult.
                  Next your going to remove all of the 6mm socket head cap screws.
                  Separate the casing halves. There are two locating dowel pins in the casing. If the casing doesn't separate easily use flat face punch to tap out the dowel pins.
                  Now pretty much everything just slides apart. To avoid headaches during reassembly, be sure to take pictures and tag/bag all of the small shims, needle bearings, etc.
                  Use a pry bar to pull the input sprocket, chain, and front output assembly out of the casing.
                  There is a small snap ring on the input shaft that holds the input shaft in the casing that must be removed. If I remember correctly you have to remove the bearing first before you can reach it, mine came out with the input sprocket.
                  Its a good idea to measure and record the location of all of your shaft seals at this point.
                  To remove the VC from the rear output shaft you have to remove this bearing. I had to heat mine to get it to come off. DO NOT loose the shim under the bearing, you need this lol. The thickness is likely going to be different between different transfer cases. As I understand it, the shim basically makes up for any differences in lengths between the rotor assembly and the casing stop faces, similar to the shim found in the rear diff for the pinion depth.
                  Everything should be disassembled by now, remove all of the bearings left in the casing or on the shafts, also remove all of the old shaft seals, be careful not to scratch the receiving bore. (I left the larger needle bearing in the input sprocket installed, couldn't source a new one)
                  Build Thread
                  Rear Diff Rebuild
                  • TehRaydarlover
                    • Mar 2013
                    • 544
                    #99
                    Time for some inspection!
                    Take some time to clean all of the parts you will be reusing. Clean the casing inside and out, I pulled the breather and replaced it even.
                    If your doing this its pretty safe to say your VC probably looks like this, o-rings blown out and nasty crap all over the inside of the t-case. Time to rebuild or source a replacement.
                    Hopefully you and your POs greased your front driveshaft splines like you should be doing. If your splines don't look like this its time to try and source a replacement :[
                    Check your chain for any excessive amounts of wear. Of the three I had to choose from, they all looked the same maybe I'm just lucky, maybe they're all junk. Maybe someone else can comment on what a junk chain looks like.
                    Check all of the sprockets, planetary gears, splines, and bearing fits for wear and damage. Replace as necessary.
                    Build Thread
                    Rear Diff Rebuild
                    • TehRaydarlover
                      • Mar 2013
                      • 544
                      #100
                      Time for the reassembly!!
                      First things first, install the shaft seals into the front half of the casing. As I'm sure you noticed there are two seals installed face to face on the front output sprocket. It's kind of a pain in the a$$ to get the second seal, I think I found a socket or something with a slightly smaller diameter to knock it in with. Make sure they go in straight, and preferably on the first try! I like to lay a very thin coat of RTV in the receiving bore while installing the seals. The RTV lubricates the seal as it goes in and also helps fill any leak causing imperfections in the receiving bore, do as you wish. With both seals installed to the correct depth we can lubricate them with some o-ring grease.
                      Next we can install the input shaft and retaining ring. The shaft just slides right in and fits loose to the casing for now. Install the retaining ring to keep it from sliding back out.
                      Next we can install the new bearing for the front output sprocket. Find something with a slightly smaller diameter and knock the bearing into place. Make sure it starts in straight.
                      Install the new bearing for the input sprocket, same method as above.
                      Now comes the tricky part, installing the input sprocket, chain, and front output sprocket. You have to first slide on the input sprocket onto the input shaft, with the chain on and front output sprocket loose in the chain. Then the sprockets need to be seated into the bearings at the same time. This is a pain in the a$$ because you have to get the front output sprocket through the two seals without it getting caught and damaging a seal. After my first failed attempt, I actually put some packing tape over the grooves to keep them from catching the seals.
                      When you get everything started and looking good you can seat the sprockets into the bearings with a dead blow hammer. Now you can also install the planetary gears.
                      You can also install the little brass or bronze crush ring. I think this little guy just keeps input and rear output shafts from being sloppy in the casing, crushing as needed to fill up the space. They are NLA from BMW so I was forced to reuse.
                      Now you can install the rear output shaft and your replacement or rebuilt VC onto the input sprocket. The gasket can also be set into place. When you order a t-case gasket from BMW it doesn't come with a gasket for the center hole. I just made one out of 0.015" gasket paper. I stuck a round file in the bolt hole to keep the gasket centered with installing the rear casing.
                      At this point apparently it was getting late and I stopped taking pictures, but its really pretty much done. The bearing shim, bearing, and shield thing can be installed on the rear output shaft, on top of the VC. Now we can install the new bearings for the front output sprocket and the end of the rear output shaft into the rear half of the casing. With the bearings installed the rear half can be installed. It may take a few tries to get the bearing and shield thing to align properly with the receiving bore but you'll get it eventually. Then all you have to do is torque the 6mm SHCS, install the rear output flange w/sealant on the splines, and torque the rear output nut.
                      Cheers!
                      Build Thread
                      Rear Diff Rebuild
                      • TehRaydarlover
                        • Mar 2013
                        • 544
                        #101
                        As for the car I'm still working on the body. I rented a bigger garage to work in and bought a welder. I've been cutting out a lot of cancer and getting ready for new sheet metal.
                        The go fast parts have been coming in also :)
                        Build Thread
                        Rear Diff Rebuild
                        • Nisse Järnet
                          • Aug 2013
                          • 1221
                          #102
                          Looking good!
                          • litu
                            • 843
                            #103
                            Wow dude that looks awesome :)
                            https://www.facebook.com/Cry_77_IX-110483784967661
                            https://www.instagram.com/cry_77_ix/
                            • TehRaydarlover
                              • Mar 2013
                              • 544
                              #104
                              Thanks! The turbo came earlier this summer too. Just starting to build the manifold now.
                              Build Thread
                              Rear Diff Rebuild
                              • TehRaydarlover
                                • Mar 2013
                                • 544
                                #105
                                Why do brakes have to be so damn expensive?? Guess I wasn't expecting to spend so much to stop 0.o
                                Current wish list...
                                Build Thread
                                Rear Diff Rebuild
