Update - didnt get to drive the car much since the weather has been hot as balls for most of July and August here and I sit in a lot of traffic coming home from work. The electric fan is not wired to any kind of temp switch and is just on a relay with a manual switch and I suspect it was not done correctly since the switch gets super hot when its in use. This, coupled with the hot temps and sitting in traffic actually melted the switch and really made me start worrying about it so I stopped driving it to work until I can sort that out.
With the weather now cooler and more enjoyable again Ive been getting back into it, and somewhat ironically decided to tear it apart to fix some problems Im really sick of. Same thing that happened last September when I was sick of driving it with no heat/defrost/windshield wipers. The exhaust is cobbled together from the PO, and while it works, it sounds awful, bottoms out all the time, flexes and squeaks and bangs off the floor/rear valence - so thats getting upgraded. The shifter assembly is also so blown out I miss 3rd a fair amount even having a good feel for where it is, so that is on its way out too. While its on stands Im also throwing some e90 drophats on to level its appearance out some, since that is pretty quick and painless.
