Burgy the Eta
  • Petebee
    • Jan 2008
    • 267
    #46
    Came to my senses. Sold the Alfa to buy a replacement Volvo for my daughter (yeah that one in the pic has a blown HG...tired of fixing the thing), and still had enough left over to paint Burgy.
    All trim removed. Tailights and front/rear windshields coming out too - just left them in until I drove the car to the paint shop (just up the road).
    • Petebee
      • Jan 2008
      • 267
      #47
      Well...painter experienced primer lifting after initial body prep and primer. We'll have to go close to bare metal to get primer to adhere. He'd sanded through 2 layers of respray but apparently it has been repainted 3 times.
      Fun part trying to figure out BMW paint code. I think it is 199. There is a Burgundrot Metallic II that is code 214, but I think it is for 87 model year only.
      Should be finished up next week.
      • HennaE30
        • Apr 2014
        • 1965
        #48
        E30zone has all the e30 paint codes iirc
        Originally posted by flyboyx
        how about if i yank the anal beads out of your ass like i'm trying to pull start a chain saw?
        Originally posted by Northern
        beer is my new liver cleanse.
        Henna - '84 Hennarot 325e
        Lola - '89 Schwarz 325is - being saved
        Christine - '88 Schwarz 325is - Spec E30 Racecar
        '01 White F150 Lariat 4x4 Supercrew - Daily
        Dad's '05 Interlagosblau M3
        • Petebee
          • Jan 2008
          • 267
          #49
          Burgy has new paint as of Friday PM. John the painter will let it cure for a few days then wet sand and compound. Then it is reassembly time for me.
          Note paint is actually b-rot not black LOL
          Area right in front of rear wheel on this side was the worst part. John seems to have got it nice and straight. He certainly put a lot of time into body prep!
          • Petebee
            • Jan 2008
            • 267
            #50
            Ordered a bunch of seals and trim including front/rear windshield seals/chrome trim, inner window seals, various trim clips and body hardware. Will also replace front windshield with a new one.
            Also got new plug wires, NGK plugs and the valve adjuster tool. I am going to adjust the valves tighter to compensate for the age of the engine. I've seen other threads where that helped quiet things down a lot.
            I swapped a portable generator that I never use for a lower mileage M20B27 long block with all accessories and a rebuilt head. I will clean up and reseal the engine. Next year we'll pull the engine, upgrade/update all A/C components (including the missing ones) and paint the bay while everything is out.
            I've PMd Stitch for a quote on some front seat covers in Pearl Beige as well. Will hunt for some period correct 15-in wheels, too. Right now I am leaning towards BBS Mahles with polished lips and Nogaro or gold centers.
            As you can tell I've decided that Burgy is a keeper, and will pour too much money into an old eta Bimmer LOL
            • 318aye
              • Jun 2010
              • 895
              #51
              Great work. Hope to see you around town.
              • Petebee
                • Jan 2008
                • 267
                #52
                Sounds good. Will likely try to make C&C in August.
                Body is painted, cleared, sanded and buffed. Really hard to make out the B-rot on the camera.
                In direct sun it looks rust:
                On the shady side it looks like Malaga burgundy:
                Hood and trunk outer surfaces painted last night. Will be sanded and buffed on Saturday so I should get the car back then. Woo hoo.
                Gonna try to strip anodized aluminum trim with EZ Off and steel wool, then wet sand and polish. Wish me luck. I don't want to put dull faded trim on such nice paint.
                • Petebee
                  • Jan 2008
                  • 267
                  #53
                  Couple of quick pics. Still need to install driver's grille when I replace broken hood cable. I'll take better shots this weekend.
                  • Staszek
                    • 2533
                    #54
                    Looks awesome, can I ask how much the paint job cost with all the prep? I will be going there soon.
                    • Petebee
                      • Jan 2008
                      • 267
                      #55
                      $3k down to bare metal sort of (see primer lift issue) PPG base + clear.
                      Sent from my SM-T230NU using Tapatalk
                      • Staszek
                        • 2533
                        #56
                        Awesome!! I was thinking $5000, I will take $3k!
                        • Stapes
                          • Feb 2015
                          • 117
                          #57
                          Your car looks great! That's exactly what I'm aiming for.
                          I'm thinking of doing as much as I can, including sanding, to save some money. Any thoughts on that?
                          • Petebee
                            • Jan 2008
                            • 267
                            #58
                            I didn't have the skill or patience to try any of the body work. Paint was just...horrible.
                            Not perfect but a lot better :)
                            Had dragging brakes so I put a new master cylinder in. Problem solved.
                            Also adjusted valves to .09 and installed new plug wires and spark plugs. So much quieter and it doesn't sound like a sewing machine. I can actually hear my exhaust leak now lol.
                            • Petebee
                              • Jan 2008
                              • 267
                              #59
                              Well car actually needed a new brake booster to remedy the brake dragging issue, but that is all sorted now.
                              Picked up a set of 15" Hartge (mfg in Japan) for a great deal and had my buddy respray them. Not quite as nice as the 16s I had to sell, but I am very happy. These have spokes that match the profile of the 16s better (slight outward, convex curve) versus the OE 15s that I have seen that have a more concave face (spokes curve inward).
                              Found some OZ caps that fit the center bore. Since some Hartges were made by OZ I feel like I'm not cheating that bad.
                              Car is a bit filthy, and I promise to take some better pics once the weather clears up and I can detail it.
