any updates??
r3v meet mutsie, a procharged fully built ls6 e30
If you want the car to handle, you may need wider tires in front.Tho only other updates I have thus far is the radiator and intercooler mounting locations. I'm putting the radiator on the outside of the core support. I had to remove and relocate the two mounts on the front valance inorder for the radiator to fit. As for the intercooler, I'm going to mount it on the driver side wheel well and run it down to the front valance. I'll post pics tomorrow of what I'm considering.
Once brakes are done I will begin on suspension then wheels and wide body. The plan is to run 17x10 with a 305/30/17 in the rear and a 17x9 with a 265/35/17 up front.Comment
I like the way you do things. Wrap it up, B.Originally posted by Andy.BWhenever I am about to make a particularly questionable decision regarding a worryingly cheap diy solution, I just ask myself, "What would Ether-D do?"Comment
Updates?How to remove, install or convert to pop out windows
Could be better, could be worse.Comment
first updates in almost a year. the car has been sitting in a storage unit 7 hours away from where i live. i finally towed it home and now im currently working on it again.
yesterday i had my pcm's unlocked and vanos removed, i will be attempting to start her for the first time in the next week or so.
today im working on installing the e36 m3 euro abs pump and controller, im currently running and soldering wires. tomorrow i will be machining the front calipers to accept my e46 m3 csl rotors. hopefully next weekend ill have the brakes mounted.Comment
