ST1G's s52 OBDII Calypsorot
  • ST1G
    • Oct 2012
    • 6689
    #301
    Yayyy. When do you plan on paint? Gonna start saving after the style 5's
    Yeah, I'm not sure on the paint. the 16 inch style 5's are easy to procure, and I'd be happy with those for a while.
    So yeah, after that save for paint.
    • slammin.e28
      שמע ישראל
      • 12054
      #302
      Matte Calypso?
      • ST1G
        • Oct 2012
        • 6689
        #303
        Matte Calypso?
        Eeew. No thanks. The calypso is so gorgeous because it's a metallic paint.
        • slammin.e28
          שמע ישראל
          • 12054
          #304
          Would totally go with a set of style nineteens.....
          • ThatOneEuroE30
            • Dec 2013
            • 8626
            #305
            :rolf:
            1991 318i 4dr slick top
            Mtech 2 turbo restoration
            • ST1G
              • Oct 2012
              • 6689
              #306
              • ST1G
                • Oct 2012
                • 6689
                #307
                Well, I went to bleed the brakes tonight and I ran into a snag. I am using a hand vac system.
                I bled the pass rear no problems, pulled fluid out until I had no more air, moved on.
                On the driver side however I pulled fluid for a little longer, hoping to flush out all the old fluid. I pulled out about 6 oz of fluid, and went to make sure I had fluid in the reservoir, curiously enough it was still full. I then pressed on the brake and it sank to the floor. I'm not really sure what to check at this point. I'm assuming there is something wrong with my master or my brake bolster? Any advice would be great.
                • ArtFoodBMW
                  • Feb 2014
                  • 765
                  #308
                  You musn't ever change your sig.
                  • ThatOneEuroE30
                    • Dec 2013
                    • 8626
                    #309
                    ST1G's Calypsorot Metallic build
                    Keep bleeding. Had it happen to me. It was just air in the system. If it doesn't work after a second good bleeding then yea something else is messed up.
                    • ST1G
                      • Oct 2012
                      • 6689
                      #310
                      ;D
                      Well, I pump and pump and pump on the brake petal and I'm getting zero pulling of the fluid from the res. I'll go out and try pumping some more.
                      • ST1G
                        • Oct 2012
                        • 6689
                        #311
                        So this is what happens when I press the brake pedal down. It sucks the fluid in, but as soon as I release it just pushes it back up.
                        • ThatOneEuroE30
                          • Dec 2013
                          • 8626
                          #312
                          this is with the bleeder valve on the caliper open yes? trying to think of what it could be.
                          • ST1G
                            • Oct 2012
                            • 6689
                            #313
                            Blender valves closed.
                            I actually got it, you were right. After putting the res and grommets back on I got it to pump up. All brakes are now successfully bled. Now comes the real life test.
                            • ThatOneEuroE30
                              • Dec 2013
                              • 8626
                              #314
                              Sweet :up:
                              • ST1G
                                • Oct 2012
                                • 6689
                                #315
                                Sweet :up:
                                The brakes are fantastic now. Better than my 4 doors ever were. I can now tell the new pads and rotors are connecting, and I get pedal feel at the top, not half way to the bottom.
                                I definitely need to go with some bigger wheels. The 14 inch caps just aren't doing it for me, and the tires will occasionally hit the fender.
