Most the parts are here. Still waiting on synchro's, timing belt and not stamped intermediate and cam gear from blunt. That will be coming later this week. I got most of the other parts though. Still need rocker arms and eccentrics. Decided I wasn't going run a cam after all just cause its not needed for my goals and was just something extra. After that it will be a matter of buying guides and piston rings and I don't wanna do that until I get my measurements on the block. After those parts are bought it will be a matter of buying the rest of the parts to boost the motor. Thinking I'll pull the motor next week.
My 1989 325is Mtech 2 Turbo restoration
Got the fabric for this cars interior today.
Originally posted by Dj Buttchug View Postthat daytona is epic
I cant wait to actually get it sprayed in my car with the mtech kit and other goodies.
I got all the parts here for rebuild except the rings a valve guides I also need to pick up the rockers. I will do that when i measure and order valve guides. I also picked up one of Otis's manifolds.
Originally posted by ThatOneEuroE30 View PostI got all the parts here for rebuild except the rings a valve guides I also need to pick up the rockers. I will do that when i measure and order valve guides. I also picked up one of Otis's manifolds.
I stock Tial 44mm MVR WG & Tial Q 50mm BOV's if you need them.Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
____________________________
E-mail Panayiotisx2@gmail.com
Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
Originally posted by Good & Tight View PostNice parts collection :) Use the stock exhaust manifold gaskets, the one's that come with the manifold tend burn out.
Thanks.
Good to know, the one I got with it was. Bent on one end and needing to be replaced.
Originally posted by ThatOneEuroE30 View PostThanks.
Good to know, the one I got with it was. Bent on one end and needing to be replaced.Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
Originally posted by Good & Tight View PostI admit there shitty :(
At least the stock ones are usually readily available unless you goof'd up and threw them away so its not to big of an issue. They are rather cheap brand new too.
Motor is out and loaded up. I will be doing disassembly and spec'ing tomorrow. Tuesday I will start grinding the valves, milling etc. Once guides and rockers are bought I will be able to assemble head.
Wheres the driveway protection:-/ where can i get carbon fiber cluster overlay
sent from my cell phoneCurrent Cars:
2016 PORSCHE GT3 RS
2017 FERRARI 488GTB
2018 RAPTOR CREW CAB
1991 318is SLICKTOP H&R SPRING SEMA CAR
1991 318IS SLICKTOP STERLING SILVER
1990 325ic BRONZIT/AUTO :)
1989 E30 M3 (SOLD AWAITING SHIPPING)
On Order:
2018 DODGE DEMON
Searching for:
CLEAN E30'S
S54 DRIVETRAIN
E30 DASH
E30 PARTS
Originally posted by 0-60 freak View PostWheres the driveway protection:-/ where can i get carbon fiber cluster overlay
Drive way is cracked and needs replaced. I also own a hell of a power washer that can get most of the shit out. I couldn't tell you where the over lay was bought. That cluster came in the trunk of the car when I bought it. I got this car as a mid project deal from a guy a in Iowa.
What stage cluch is the Spec clutch?Projects Hartge,Alpina & AC Schnitzer Builds.http://www.r3vlimited.com/board/showthread.php?t=280601
Originally posted by e30m3s54turbo View PostWhat stage cluch is the Spec clutch?
Trying to remember if its stage 2 or 3. Its rated to 500ft lbs of torque or something like that.
