SI Shift Lights - by E30 Innovative Goods
Committed to excellence!
Our threads:If you don't know that there's a lot you don't know, you think you know everything.
E30 One-Touch windows
E30 Intelligent wipers
E30 Econo gauge - still R&D
E30 SI Shift Lights
E30 Hazard Switch Multigauge - still R&D
Feedback thread:
Our pages:
http://www.e30ig.com
https://www.facebook.com/InnovativeG -
List for the second batch:
1.) Harrisfb - qty 1
2.) Jamese30 - qty 1
3.) Kid325e - qty 1
4.) ThatOneEuroE30 - qty 1
5.) nomansland92 - qty 1
6.) SixerFixer - qty 1
7.) eur04lif3 -qty 1
8.) dude8383- qty
9.) Aitch - qty 1
10.)TehRaydarlover -qty 1Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Build Thread
Rear Diff Rebuild
Rebuildable Viscous Coupling
Transfer Case Rebuild
"Life is simpler with 12 valves"Comment
E30 SI Shift Lights
Feedback thread:
Our pages:
https://www.facebook.com/InnovativeGComment
E30 Innovative Goods projects - SI shiftlights, hazard switch multi gauge...
Do you have any idea when the second batch will be in? Are these light now "plug and play" like install bored to the main board make holes for lights and the Watch the awesomeness? Also how do you tell if you have the 7 or 9 led clusterComment
Not yet, we are still working on the first batch. We have the main LED boards ready. We need to finish the adapter boards and R3V calibration boards to make the adjustment possible.
Shiftlights are almost "plug and play", there will be some calibration to do on your side to adjust he thresholds to your liking.
Early cluster with 9 SI LEDs, note 3 red LEDs.
Late cluster with 7 SI LEDs, note 1 red LED.
E30 SI Shift Lights
Feedback thread:
Our pages:
We're sorry to bring you little bad news.
Our ordered PCB's for the r3v calibration board came in faulty. We're really pis.. off :curse::curse::curse:
If you know anything about PCB-s you will be able to spot the fault in no time.
We filed a complaint and were prommised to receive new PCB in 10 days.
Please be patient. We are doing all we can so that you receive your boards as soon as possible.Committed to excellence!
E30 SI Shift Lights
Feedback thread:
Our pages:
Any updates? New boards?Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Build Thread
Rear Diff Rebuild
Sorry for the delay.
We received the new boards two days ago, but we wanted to test them and make sure they are good to go.
They are!
All that is needed now is a few days to finish the soldering for the first batch. It should be done by the end of the week. When you receive the boards and see the size of them you will see this is not an easy job.
In a day or two we will send you via PM the details on how to pay to each of you that are on the first batch.Committed to excellence!
E30 SI Shift Lights
Feedback thread:
Our pages:
Awesome, looks great! Can't wait for the second batch.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Build Thread
Rear Diff Rebuild
During the installation process, you will define the MIN and MAX thresholds. MIN setting are RPMs where the first LED will turn on. MAX setting are the RPMs where all LEDs will be flashing.
These thresholds are dependent on engine temperature. This is why you will define MIN and MAX thresholds for cold and hot (working temp) engine. Don’t worry everything is explained in the installation part of the manual.
LEDs brightness can be adjusted.
We even added optional Day/Night jumper pins, where you can connect a switch to toggle between day and night LED brightness.
To use this option you will need (not included in the package):
• Two pin jumper wire like this one, long enough to reach the desired switch position: click here
• ON-OFF switch which you can mount anyplace in the car
Note that the LED brightness when MAX RPMs are reached is always at FULL power regardless of the Day/Night switch position and set LED Day or Night brightness.
Package contents:
• Shiftlights board 1x
• R3Vgenerator board 1x
• Adapter board 1x
You will receive the invoice to your Paypal email in the next few days. Just waiting to receive info from all of you on the first batch to send them all at once.Committed to excellence!
E30 SI Shift Lights
Feedback thread:
Our pages:
