Aussie 318is - now S54B32 swap
  • jeenyus
    • Aug 2011
    • 2064
    #91
    Originally posted by AusScare
    Yep will be a handful :)
    My Plazmaman order arrived, billet aluminium 72mm throttle body, intake manifold and fuel rail.
    Welds on point:
    WOW! This is a work of art. I would hang that on my wall.
    • AusScare
      • Jun 2014
      • 220
      #92
      My ECS order arrived, replacing a few old, worn and degraded parts inside and out. My driver's seatbelt receptacle had actually stopped springing back, forcing me to wedge it back up with each use, so this is a welcome replacement.
      New vs old washer jets:
      Old vs new elephant trunk seal for the engine bay:
      New vs old inside door handle surrounds. New ones snapped nicely into place, compared to the old ones which sort of just sagged there:
      Original battery cover was victim to a diff rolling around in the boot, and although it came up ok with some glue and a respray, the new piece sits in place much more nicely:
      No more scratched and worn M cover on the steering wheel:
      Bonnet bump stops:
      Lock surrounds:
      The rear sway bar links will go in at the same time as the new rear sway bar poly bushes - which will be when I buy some BC Racing Coilovers for the car.
      I also bought a small storage bin from ECS, but tuns out it's actually for an e36, so useless to me!
      All photos taken on my Pixel 2 XL - can't get over how good the camera is.
      '90 318is
      • AusScare
        • Jun 2014
        • 220
        #93
        Overnight parts from Japan.
        Brand new 300ZX gearbox from Nissan. This, matched with the Alpha Omega conversion kit and OS Giken twin plate clutch should manage the power and hopefully not break!
        '90 318is
        • econti
          • May 2014
          • 1152
          #94
          Oh wow, how much is that worth? 5k?
          • AusScare
            • Jun 2014
            • 220
            #95
            The gearbox itself was ~AU$2,800 including shipping.
            The conversion kit was AU$1,500 locally.
            Clutch was AU$1,500 from Japan.
            So yeah around AU$6k when you add the shifter, clutch slave cylinder, etc.
            Sent from my Pixel 2 XL using Tapatalk
            '90 318is
            • AusScare
              • Jun 2014
              • 220
              #96
              A few maintenance parts came in just before Christmas. Not the most exciting order, but important to keep the car in good shape.
              First was the sunroof seal. Off comes the sunroof:
              Old seal removed, area cleaned, some minor rust removal, treatment and painting on the underside:
              Then back on the car:
              Headlight trim rings came off:
              Coat of paint to even them out. These really need a proper machine sanding as there are many layers of chipped old paint on them. I just did a quick job to keep the colour even:
              Old hood insulation looking pretty sad. I got tired of it dropping all over the engine bay:
              Part way through removal:
              And new insulation in place:
              New caps for the wipers:
              And difficult to see, but I replaced both window seals in the doors. This was a glass out job and I definitely needed my partner's help to do it (managed to scratch the tint on the drivers window trying to do it myself):
              Also for those wanting to do an SR20 conversion, Audi R8 coil packs are a nice option, and much cheaper than other aftermarket coil packs.
              '90 318is
              • econti
                • May 2014
                • 1152
                #97
                A friend of mine does conversion harnesses for them too, syltech on ebay I think he is
                • AusScare
                  • Jun 2014
                  • 220
                  #98
                  Have been a reasonably regular attendee at the local cars n coffee. Friend has the old Range Rover, so always good for a chat:
                  I picked up some new (to me) wheels, the familiar TRM C1 in 15x8 +20:
                  New tyres are Hankook RS4 in 225/45R15:
                  Those Audi R8 coilpacks from a few weeks back:
                  Recent Taarks order came through with a range of SR20 parts to hopefully finalise the SR build. This included an oil filter relocation kit. The filter kit required some flow improvements inside, as it contained big 'steps' down where it had been machined.
                  Smoothed out:
                  Enlarged:
                  Stained:
                  '90 318is
                  • Tzantushka
                    • Nov 2018
                    • 390
                    #99
                    Great progress!
                    BTW - with our crappy exchange rate against the USD, I found Schmiedmann to be less $$$ for certain PE parts.
                    E30 320i vert
                    But daily drive is Volvo V60 Polestar
                    • AusScare
                      • Jun 2014
                      • 220
                      #100
                      Originally posted by Tzantushka
                      Great progress!
                      Thanks. Yep, most of my orders are from Schmiedmann. I'm looking to get new brake calipers (stock size) next, so am doing some comparisons on pricing between them, ECS and Pelican.
                      '90 318is
                      • jeenyus
                        • Aug 2011
                        • 2064
                        #101
                        nioce! cool to see this keep going. an SR20 e30 is probably a perfect combination.
                        • AusScare
                          • Jun 2014
                          • 220
                          #102
                          Sorry for the lack of updates - the e30 has been my faithful weekender over the last few years, but also life has taken over - since 2019 I've gotten married, had a honeymoon, bought a house, had a baby. The last few months I've started researching more upgrades.
                          Took it to a few cars and coffee events:
                          Drove to Bunnings (hardware store) a few times:
                          Cruised around with the dog:
                          '90 318is
                          • AusScare
                            • Jun 2014
                            • 220
                            #103
                            Replaced the tail shaft centre bearing, because it was wasted:
                            Had the tacho upgraded to reach 9000rpm in preparation for the 8400 rpm redline of the new motor:
                            Bought a new turbo, Pulsar turbo, a knockoff of a G30-770. A friend runs these on his 800hp twin turbo LS1 with success:
                            '90 318is
                            • AusScare
                              • Jun 2014
                              • 220
                              #104
                              Anyway, off to GreshM Performance today to fix a major coolant leak from the water pump and a few upgrades..
                              - New clutch, tailshaft rubber coupling, water pump, 80'c thermostat, power steering reservoir and low pressure line, misc engine lines that have degraded
                              - Hillside Motorsport reinforced front & rear subframes, reinforced rear trailing arms
                              - Racing Diffs (Serbian company) billet dual mount, finned, diff cover for my 4.1 ratio medium case lsd
                              This will get the car reliable again engine wise, while I wait for my sr20 to be built, so that I can keep driving it around. The diff/subframe upgrades will be useful when the car makes more power. The original front subframe is currently cracking around the engine mounts anyway.
                              I also picked up a set of BBS RS 071 wheels in 15x8 +18 (front) and 15x8.5 +12 (rear) off FB marketplace. I had alerts running for 2 years before these turned up. These BBS wheels are built in the 80s for e30 race cars, so are the perfect spec.
                              I dropped these off last week at Dr Wheels in Yatala (Brisbane, Australia) to be rebuilt:
                              - Barrels painted black
                              - Centres & waffle plate painted nogaro silver
                              - Polish hex caps & lips
                              - Supply new valve stems and bolts
                              - Reassemble
                              I'll then need a set of coilovers so that the car doesn't look like a 4x4 with these wheels. Leaning towards KW V3's.
                              '90 318is
                              • DEV0 E30
                                • Oct 2004
                                • 8904
                                #105
                                Very nice progress and plans!
