New e30 member.
  • slatersbro
    • Oct 2014
    • 12
    New e30 member.
    Hey guys, my name is Matt.
    I own a 84 318i that I have been working on for a while now. I picked it up a couple years back for $250.00 with a leaky headgasket then proceeded to teardown the m10 for improvements. build components so far include.
    90 mm forged JE pistons
    Total seal rings
    Cometic mls
    Ireland engineering crank scraper
    Schrick valve springs
    Fresh bearings
    Schneider custom ground turbo cam
    Heavy duty rockers.
    Split second additional injector controller with timing retard.
    My reason for building the m10 were fuel economy and the benefits in handling from a low weight powertrain.
    I am very happy with the outcome. The car certainly Isn't the fastest but it shines in the corners.
  • LJ851
    • 7919
    I like it. Why do you have 2 AFMs ?
    Lorin
    The M30 is God's engine.
    • BLACKCHARM88
      • Jun 2014
      • 563
      Props on the intake manifold build, looks good man.
      • slatersbro
        • Oct 2014
        • 12
        Thanks. The car was in mock up stage in the pic. I just hadn't removed the second one at that point.
        • dugly52
          • Oct 2012
          • 372
          Looks great. I like the plate/blinker delete on the DBs. What kind of numbers you putting down out of that M10?
          Project: 87' 325iS... 325iS
          88 Alpine 325i
          1/2 88 325iX
          • Mirek E.
            • Sep 2013
            • 105
            From where are you getting vacuum for an internal wastegate and what type of injectors do you use?
            318i M10 '87
            • E30_Pare
              • 7801
              awesome... awesome to the max
              DREWLIENTE
              1$ PShops PM me
              • Andy.B
                • Sep 2011
                • 1650
                Awesome looking build!
                • slatersbro
                  • Oct 2014
                  • 12
                  Thanks guys.
                  • e30m3s54turbo
                    • Jun 2010
                    • 3290
                    I like the m10 turbo. The intake looks awesome. How much power do you expect get?
                    • slatersbro
                      • Oct 2014
                      • 12
                      Not sure yet on numbers. Missed a group dyno day last weekend. I will post as soon as I go.
                      • slatersbro
                        • Oct 2014
                        • 12
                        I'm running stock primary injectors with two 42lb secondary injectors driven by my split second injector controller.
                        Pressure is supplied from nipple on compressor housing.
                        • Ray Smoodiver
                          • Jun 2004
                          • 8809
                          I like where this is headed.
                          • ak-
                            • 12422
                            I think it's fantastic that you turbocharged an m10.
                            Car sounds like a blast to drive.
                            1991 325iS turbo
                            • arthurmdk
                              • Feb 2014
                              • 27
                              Wow this is badass!
