E30 Turbo Project, Budget done right(Ha.Haha)Twincharged Next
m20b27 Turbo. Hx35. Twinscroll Mani. MS1. 42lbers
http://www.r3vlimited.com/board/showthread.php?t=338818
Originally posted by E30NJ View PostThat copper wire hidercomplements well with that polished valve cover. Nice work good luck on the twincharger
Originally posted by efficient View Postvery nice!
i need to finish my turbo setup aswell.
my car looks like yours except my car is a coupe. my paint is chipping like yours showing the original bronzit color in some places.
where did you get the 42lb injectors?
So the head is .005" out in the middle and the first machine shop I went to doesn't want to surface the head, even though it would still be well within the Bentley's spec. I am tentatively looking for a new head just so I'm not on the edge of the spec, but either way I have my sights set on a forged 24v motor in the future
Originally posted by RondoAcapriccio View PostThe only thing I don't like about this thread, is that there are no videos.
Little update, I should be picking up an m50tu from an e34 on wednesday. The plan is a 3 liter stroker, and of course turbo, not sure about the eaton
My hopeful parts list:
M54 crank and pistons
Eagle rods/arps bolts. 135mm
Schrick 256/264 cams
11mm arp headstuds
arp mains
blunttech mani
66-76mm garrett or precision snail.
Finally picked up an m50, I was about to go s52 but found an m50 block with low compression wisecos for $300. Picked up an m52 crank and some 130mm h-beam rods to get a 2.9l, kind of m20 style. Im scrapping the twincharged idea for now and going with a holset he351ve with a 67mm billet compressor wheel. The plan is to control it with ms3x but if I can't figure out the CAN bus communication I have a design for a mechanical actuator.
Also using a non-vanos head for the single piece valves and dual valve springs. I'll convert it to vanos at some point.
Some pics of the pistons and rods
Cutting the o-rings
I'm excited to experiment with the vgt turbo, the recent Megasquirt development should make it possible to control the actuator and I have hopes the vanes will last with e85 and meth to cool the egt's
