M30 OEM Turbo project
  • ThatOneEuroE30
    • Dec 2013
    • 8626
    #256
    Nicely done. I got bmp design guage pod if you wanna use that instead ;)
    1991 318i 4dr slick top
    Mtech 2 turbo restoration
    • CorvallisBMW
      Long Schlong Longhammer
      • 13039
      #257
      Ya the BMP one is nice too
      • ThatOneEuroE30
        • Dec 2013
        • 8626
        #258
        75 shipped and its yours haha
        • CorvallisBMW
          • 13039
          #259
          If for some reason this doesn't work out, sure.
          I also got a nice package in the mail from George Graves today. Photos soon, but for now, here's a stocker:
          • 2mAn
            Señior Mod
            • 20988
            #260
            I am going to add the oil temp and pressure gauges, but I want them up in my line of sight.... A pillar gauge pod yo!
            Simon
            Current Cars:
            -1966 Blue Boat
            -1969 Red VW
            -1986 White BMW
            -2006 Green Thing
            Make R3V Great Again -2020
            • CorvallisBMW
              • 13039
              #261
              I need some advice on the exhaust gaskets (or lack thereof). RealOEM gives 2 pictures of exhaust manifolds for the 745i. One is obviousely correct and lists no exhaust gaskets, aside from the rings that are set in to the manifold, #15 p/n 11621706800
              The other picture listed is clearly not the correct manifold, but it does list a gasket for #3, p/n 11621723851
              Should I use an actual exhaust gasket? I could reuse the standard m30 gaskets and heat shields, but will that cause a problem? I'm totally confused
              • ThatOneEuroE30
                • Dec 2013
                • 8626
                #262
                Hmmm may have to ask my friend with running m106 what he did
                • CorvallisBMW
                  • 13039
                  #263
                  All done, including Instagay filter
                  • Dmitry
                    • Mar 2015
                    • 66
                    #264
                    great work a thread! totally share your approach with BMW stock components! good luck, tolerance and money for project!
                    • CorvallisBMW
                      • 13039
                      #265
                      Many things were accomplished this weekend!
                      Swapped the old S3.73 for an S2.93
                      Then worked on getting the exhaust manifold on. It's a bitch to attach because I can't thread in the studs and then slide the manifold over them; not enough room. The only way to make it all work is to hold the manifold against the head, try and line up the studs, and thread them in by hand. And then insert the copper sleeves. So to make it slightly easier I put a small slit in to the end of each stud. This lets me use a stubby flathead screwdriver to help seat the studs.
                      Hit with some paint to prevent corrosion
                      Ready with copper sleeves and anti-seize
                      And finally done!
                      • CorvallisBMW
                        • 13039
                        #266
                        It was also a good opportunity to mount the wastegate. I know heat management is goi to be tricky, and the e30 engine bay is much narrower then the e23 bay, meaning all the exhaust stuff sits much closer to the fenders and other parts. I ordered some gold heat foil and fire hose from Summit, and got to work.
                        The wastegate sits just behind the shock tower. After some crude measuring and cutting, I had the gold foil applied. There's also a brake hardline here that I was concerned about, so I wrapped it in fire hose. Sorry for the shitty picture.
                        Mounting the wastegate mean making a few modifications to my tools. The top nut is fairly easy to get to with a 12-point wrench. The bottom one is not, there's almost zero clearance.
                        Since I don't have a bench grinder, well...
                        I also took the time to reinstall the radiator, 10" puller fan, and alternator.
                        • IronFreak
                          • Dec 2012
                          • 3702
                          #267
                          Very nice work, methodical and planned out......I should take notes. I get insane ADHD when I start working on my car.
                          Instagram @rebellionforge
                          • ThatOneEuroE30
                            • Dec 2013
                            • 8626
                            #268
                            Man this is looking great. I'm taking notes for sure!!!
                            • Anthony B
                              • Nov 2012
                              • 308
                              #269
                              Absolutely loving this build, your attention to detail is brilliant
                              Quick question, what poly engine mounts are you using? I have rubber ones in my m30 swap(used from the car the swap was originally in) & i have little to no faith in them
                              • CorvallisBMW
                                • 13039
                                #270
                                The mounts are from 'G-Man the Visionary'
