I saw this, and thought you would like to know.
M30 OEM Turbo project
I saw this, and thought you would like to know.How to remove, install or convert to pop out windows
Could be better, could be worse. -
Got a pic from my exhaust guy. Factory down pipes with an added bung for the wideband sensor, combining in to a 2.5" single with v-band clamp and factory O2 sensor. Eventually (after the picnic) I'll have this whole section ceramic coated.
That is weird that your down pipe is twin piped mine is only one.Comment
One pipe is for the turbo, the other is for the wastegate. What does yours look like? Where does your wastegate dump to?
Actually yes, it fits in the trans tunnel between the chassis and trans.Comment
Check this out! A month ago I started on this project to mount a voltmeter in the check panel:
Well I broke the faceplate trying to cut out a relief for the gauge to show through, so I needed to get another one. I sourced one from Wishno87 and decided to try a different route. The black coating comes off really easy with brake clean, so I just taped off the window I needed and went to town!
Looks perfect!
Reinstall the guts
Run the wires through the open bulb holes in the back:
And voila!
^ I have been wanting to do something similar.How to remove, install or convert to pop out windows
Could be better, could be worse.Comment
Mine looks like yours except the wastegate comes back down into the turbo pipe and exits with the turbo
Basically take the Y off yours and just keep running the pipes straight from the turbo flange back and then somewhere along the line add the piping up to the wastegate flange and a O2 sensor bungComment
Gonna have to pop into the storage shed and snap a pic of mine.Comment
Please do, i'd like to see it. I was under the impression that all the m102/m106 downpipes were the same.Comment
I'm tripping they are the same he just left me more of mine which made me think it was different.
When I get to doing mine I think I'm gonna have a 3 inch down pipe made up so I can run more boost and the tail wastegate.Comment
All 745i's were factory dual exhausts all the way back; yours was cut up and modded in to a single at some point in it's lifetime. If you're going to a 3", you might be able to reuse the wastegate tube and just tie that in to your new downpipe setup. Just be aware that 3" single exhausts tend to drone like a bitch.Comment
O I know. My 2.5 on the late model drones like a mofo would just do it for the power gains. I'm gonna run this one first for a while.Comment
