M30 OEM Turbo project
  • efficient
    • Feb 2012
    • 3312
    Cool
    • golde30
      • 11464
      Kronus was going for this swap on his Alpine euro e30, but gave up. Cant wait to see it completed.
      IG: @Baye30
      • uturn
        • Dec 2010
        • 1006
        I've dreamed of this but read somewhere that the strut tower will need to be modified to fit the OEM turbo/manifold, something I can't bring myself to do. I will forever live in NA purgatory.
          • 37833
          Yes sir, I do like this thread.
          Grover Beach, California
          BimmerHeads.com
          • ttrousdell
            • Nov 2009
            • 1770
            Looking forward to updates. I like the idea of going all oem.
            The Build:
            • E30NJ
              • Aug 2013
              • 921
              Good work! Wasn't that KKK turbo in all of the early 2000's A4 and A6?
              • chadthestampede
                • Jul 2008
                • 3601
                At least you have a garage. My wife and I bought looked at 40 houses and the one she wanted the most had no garage. /cry
                Anyway nice build.
                Originally posted by LJ851
                Feedback
                • Good & Tight
                  • Apr 2004
                  • 2057
                  This will be a cool build ..!! I think part of the shock tower bracing needs to be trimmed to fit the wastegate and turbo might interfere with engine arm bracket.
                  Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
                  ____________________________
                  E-mail Panayiotisx2@gmail.com
                  Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
                  • CorvallisBMW
                    Long Schlong Longhammer
                    • 13039
                    I'm starting the process of mocking everything up, so hopefully I'll have some answers soon. The "kit" came with the original passenger side e23 745i motor mount arm, which is different from the standard 735i arm. But since it's designed for the e23 chassis I highly doubt it will work in the e30. I may be getting in touch about a custom one...
                    • CorvallisBMW
                      • 13039
                      Time for some more updates! Still rebuilding the turbo.
                      Next step: remove compressor plate held on with 4 torx T-40 bolts:
                      Once removed, you can see the 3/4 thrust bearing. I had to clean and scrub quite a bit just to get to this, it was covered in charred oil and junk. Also note how blackened the bearing is. It's supposed to be shiny, bright bronze.
                      Next up: use a pick to remove the thrust bearing, snap rings, and bushings.
                      OK kids, everyone in the pool!
                      The main shaft was pretty dirty and had some burnt crap on it, so before everything can be put back together it needed to be cleaned and polished up a bit. Thankfully I had some 3000 grit wet sandpaper laying around. Chuck it up in a drill and 30 seconds later, voila!
                      I've been working on my shaft polishing skills, Blunt will be so pleased! :giggle:
                      • CorvallisBMW
                        • 13039
                        I also started tearing apart the wastegate. It's in good shape but my plan is to get the bottom half sandblasted and the whole thing painted to match the ceramic coating that's going on the rest of the exhaust system.
                        • ThatOneEuroE30
                          • Dec 2013
                          • 8626
                          I like this thread keep on doing what your doing
                          sub'd
                          1991 318i 4dr slick top
                          Mtech 2 turbo restoration
                          • CorvallisBMW
                            • 13039
                            More updates to come tonight!
                            • kronus
                              • Apr 2008
                              • 13032
                              you can theoretically mod that wastegate to make it adjustable, btw
                              I still have all my M106 turbo bits too if you need anything
                              what are you doing for management?
                              cars beep boop
                              • eduTechnic
                                • Dec 2012
                                • 400
                                Sub'd, turbo verts are awesome.
                                Turbo M50 4 Door Build thread here 4 Sale thread
