M30 OEM Turbo project
  • CorvallisBMW
    Long Schlong Longhammer
    • 13039
    #661
    Best guess is 1-2 weeks. Some of the parts they had to order from The Fatherland, so that pushed out completion by a bit.
    • AndrewBird
      The Mad Scientist
      • 11896
      #662
      I bet I could put together an adapter for you. I do have access to lots of equipment (4k watt laser, CNC mills, etc...). Got pics of an adapter someone else has made?
      • CorvallisBMW
        • 13039
        #663
        Sadly no, so far all I've come up with is that CAD drawing that shows the dimensions of the OEM valve and mounting plate. The tricky parts to figure out are 1) can any of the aftermarket WGs be separated, i.e. remove the elbow from the spring/diaphragm/valve assembly? and 2) How long is the valve stem and what is it's movement range from open to closed? Machining an adapter isn't too hard, but the other part involves me buying a $350 WG and then proceeding to tear it apart and possibly destroy it...
        • ThatOneEuroE30
          • Dec 2013
          • 8626
          #664
          Just buy something like this and save a few bucks.
          I have a 44mm that just laying around for parts but will be to big for your application
          1991 318i 4dr slick top
          Mtech 2 turbo restoration
          • scarsofcarma
            • Mar 2017
            • 26
            #665
            Subscribed, lots of good info here to help with my M30 turbo build. Kudo's! :coolphoto:
            • CorvallisBMW
              • 13039
              #666
              My EBC setup arrived from DIYAutoTune yesterday. The setup is super easy. Since I still don't have the Tial adapter, I'm going to have to put the stock WG back on for now, hence the single-port configuration:
              The kit comes with 1/8" barbed fittings, but my lines are 3/16", so I had to get a couple of new fittings
              All installed, along with a plug for the unused port.
              And mounted on the old airbag sensor bracket in a vibration-resistant clamp.
              There are only 2 wires to connect. One goes to a switched 12V source, the other to the COM port on the back of the ECU. Easy!
              • CorvallisBMW
                • 13039
                #667
                I just received some photos from the guys at G=Pop shop of the turbo, it's looking great!
                New billet compressor wheel. 53mm inducer, 78mm exducer.
                Attached to the turbine shaft:
                And the CHRA, now ceramic-coated
                • bradnic
                  • Jul 2012
                  • 3550
                  #668
                  that is seriously sweet looking. built to last.
                  HOWTOs:
                  DB vert plastic bumpers
                  OEM Keys
                  MTech1 docs
                  88 ix Lach/Card
                  91 ic Calypso 3.1
                  86 Cosmo 2.7
                  OEM+ or bust!
                  • CorvallisBMW
                    • 13039
                    #669
                    Some more turbo photos
                    • bradnic
                      • Jul 2012
                      • 3550
                      #670
                      all balanced? how were the parts marked?
                      HOWTOs:
                      OEM Keys
                      MTech1 docs
                      88 ix Lach/Card
                      91 ic Calypso 3.1
                      86 Cosmo 2.7
                      OEM+ or bust!
                      • CorvallisBMW
                        • 13039
                        #671
                        You can see the red paint on the compressor wheel. I have some more photos of the complete, assembled unit with all the balancing marks, but photobucket is being a little bitch right now and I can't seem to upload them.
                        Interestingly, they applied ceramic coating to the exhaust housing even though I'd already had that done. So now there's two layers of coating on the housing, plus a turbo blanket. If this doesn't keep down the underhood temps, nothing will! Add in the coating on the CHRA, the new heatshields, exhaust coating, and exhaust wrap, and this thing should be as insulated as humanly possible :up:
                        • bradnic
                          • Jul 2012
                          • 3550
                          #672
                          beautiful man. my favorite turbo build. nothing comes close.
                          HOWTOs:
                          OEM Keys
                          MTech1 docs
                          88 ix Lach/Card
                          91 ic Calypso 3.1
                          86 Cosmo 2.7
                          OEM+ or bust!
                          • ThatOneEuroE30
                            • Dec 2013
                            • 8626
                            #673
                            Have you gone to a front mount intercooler?
                            • CorvallisBMW
                              • 13039
                              #674
                              Ya, it's back on page 30-something IIRC
                              • ak-
                                • 12422
                                #675
                                Shit, did I tell you one goes to ground instead of 12v and the other to the ECU?
                                Sorry if I confused you.
                                1991 325iS turbo
