M30 OEM Turbo project
  • ThatOneEuroE30
    • Dec 2013
    • 8626
    #76
    Looking good
    1991 318i 4dr slick top
    Mtech 2 turbo restoration
    • CorvallisBMW
      Long Schlong Longhammer
      • 13039
      #77
      Originally posted by kronus
      that's surprisingly tidy. what are you doing about the AC line?
      also, move up the IC if possible so that it has room for airflow out the back.
      I'm not sure yet on the AC line, I may have to have it custom made once everything for the turbo is in place. There's a good amount of room behind the IC, so with a fan mounted to it I think I can get some decent airflow. It'll be warm engine bay air, but still probably better than nothing... maybe?
      Actually come to think of it, not having to mess with an IC would make this much easier. How necessary is an IC on a system that's only putting out like 8psi?
      • golde30
        • 11464
        #78
        my old datsun 280zxt ran 14lbs boost on an otherwise stock engine configuration, which had no intercooler...
        IG: @Baye30
        • G-Man the Visionary
          • Apr 2013
          • 543
          #79
          I don't think there is a cooler project... Great work, love the OEM!
          Streetable poly mounts, trans mounts are here!
          http://www.r3vlimited.com/board/show...ght=streetable
          '94 318i
          '07 335i
          '11 X5
          '89 325ic m30b35
          • Mr. Tasty
            • Jul 2011
            • 3421
            #80
            what about eliminating the intercooler and introducing water or water/meth injection after turbo?
            2014 Alpine White 335i MSport
            (Daily Driver)
            Full Mperformance Aero
            KW V2 Coilovers
            VRSF Catless Downpipes
            • LJ851
              • 7918
              #81
              TCD stage 1 turbo kit does not use an intercooler. I believe it is in 7-8 psi range.
              turbochargingdynamics.com is available for sale! Check it out on ExpiredDomains.com. turbochargingdynamics.com is in high demand, secure it today!
              Lorin
              The M30 is God's engine.
              • Ether-D
                • Sep 2011
                • 2838
                #82
                My supercharged m20 is about 9psi and it's not intercooled. It's extra kickass in the winter. I do notice it pulling timing in the summer.
                Originally posted by Andy.B
                I was born on 3/25…
                • ThatOneEuroE30
                  • Dec 2013
                  • 8626
                  #83
                  You already got the intercooler. Why not run without it. If you don't like how it runs, figure out a way to install it.
                  • IronFreak
                    • Dec 2012
                    • 3702
                    #84
                    I've seen plenty of domestic turbo builds without intercoolers. especially at no more than 8psi. like mentioned above, hit that with a meth kit and you'd be golden.
                    Instagram @rebellionforge
                    • 2mAn
                      • 20059
                      #85
                      As far as the BBQ paint, I've yet to find any paint that will hold up to NA exhaust temps for more then a few months. If someone had a better solution, let me know.
                      Mines been holding up fine, but I also threw it in the oven like the OP.
                      Originally posted by tak7
                      keep on tinkering...
                      THIS!
                      I'd keep the intercooler because you know if 8 psi is good, then 10+ psi will be better. Keep it up!
                      I remember this car from the Dyno Day at the shop in Portland a few years back. My old ETA put a thundering 90whp down that day :rofl:
                      I remember you were upset about the numbers your car put down compared with the other M30 car(s). Im sure that exhaust had something to do with it. Do it right this time!
                      Simon
                      Current Cars:
                      -1966 Lotus Elan
                      -1986 German Car
                      -2006 Volkswagen Jetta TDI
                      Make R3V Great Again -2020
                      • CorvallisBMW
                        • 13039
                        #86
                        THIS!
                        Yes, it was way down on power. I think most of that had to do with the Miller system not being tuned well (I used there off-the-shelf 91 octane tune). With the old AFM re-installed and a new ssquid tuning chip, it pulls harder than ever. My challenge now is to decide whether to run the turbo with the Miller setup or go Megasquirt... I know everyone will say MS, but considering I already have the Miller stuff, it's a matter of free vs $$$.
                        • Pantless Spency
                          It's McRib time!!!
                          • Feb 2011
                          • 7284
                          #87
                          keep up the great work!
                          • ThatOneEuroE30
                            • Dec 2013
                            • 8626
                            #88
                            I just realized your running AC. How come? Would removing it make life much easier?
                            • LJ851
                              • 7918
                              #89
                              Do you really not know the answer to this question ?
                              Lorin
                              • ThatOneEuroE30
                                • Dec 2013
                                • 8626
                                #90
                                lol I do. But I was wondering why since most people that run turbos remove them first thing to save weight and make life easier for doing the piping. I worded that all wrong made me sound like a dumbass.
