View Post
I give it 6months. while Miller is excellent for N/A cars it fueling seems to depend on RPM vs true airflow.
for example if you only make a couple psi in first but your tuned for lets say 7psi in 3rd gear, you'll run very rich in first gear because it will send the same fuel amount for that RPM even though there is much less air flow in that gear. you can always get a medium AFR, example- not so rich in first and then a bit lean in other gears but a turbo E30 deserves better!
