Phoenix e30 -1987 Royalblau 4 door 24v project
  • brshelton
    • May 2014
    • 102
    A little late starting my build thread but better late than never. Big shout out to PimpinWalrus. This wouldn't be happening without his garage, and probably not without his help either. Also thanks to chinampa and my friend Morgan.
    All pics can be found at: https://www.flickr.com/photos/fckbenshelton/
    I bought my e30 originally as a 91 Alpine 4 door slicktop with a obd1 m52 swapped into it on billy sports/hr oe sport and worn out everything else. It had ripped blue cloth interior. Over the course of a year of owning it I did a LOT of work to it but I rear ended someone on December 16th. I decided buying a very clean car I knew of local, parting it, and reshelling everything was the route I was going to go...and so it began.
    Got the car at 181k but it was already swapped
    OBD1 M52 175K
    ZF Trans 175k
    7 series/325ix double diaphragm booster 175k
    Was untuned and running the wrong injectors
    21.5 lb pink tops 183k
    TRM Chip 183k
    All 4 boots were ripped and changed fluid in trans and diff (3.25 diff got replaced later with a 3.46)
    Axle Boots 185k
    Gear Oil in Trans 185k
    Ordered the intake one night drunk as hell cuz itd look sweet with the carbon fiber YO
    KA Motors Intake 186k
    ZHP Knob 186k
    This blew out one day and I had to change it in the snow
    Valve Cover Gasket 187k
    Needed to start getting rid of all these worn out parts and making it less bobo.
    Green CABs 188k
    Control Arms 188k
    Ball Joints - Febi/Bilstein 188k
    Sway Bar Endlinks Front 188k
    Spark Plugs - BKR6E iirc 188k
    Grip for days (and real wheels)!
    TRM C1 15x8 ET20 189k
    Hankook RS3 189k
    Busted my oil pan after I installed IE3 springs
    E34 Oil Pan 190k
    Oil Pan Gasket 190k
    Oil Level Sender Gasket 190k
    The RS3 demanded more braking power to utilize all that grip
    Rebuilt OEM Calipers 191k
    Stainless Steel Brake Lines and clutch line 191k
    Centric Slotted Rotors 191k
    Hawk HP Plus Pads 191k
    This was all done at once
    BC Coilovers 10k/14k 6" 192k
    E36 steering rack 3.2 192k
    Tie Rods - Lemfoerder 192k
    Steering Rack Boots 192k
    3.46 LSD 192k
    75w90 Redline Diff Fluid 192k
    Condor P/S Loop Kit 192k
    Serpentine Belt 192k
    Raceland Euro M3 Rep Longtube 192k
    Stainless 3 inch 2 mufflers 192k
    Magnaflow y pipe 192k
    Summit Vbands 192k
    Exhaust Manifold Studs and Nuts 192k
    Snapped a subframe bolt during install of it all
    Subframe Bolts - 10.9 Yellow Zinc 192k
    Put winter tires on
    Kumho Ecsta 4x 205/55/15 194k
    Of course once I started the project I decided that while I was in there I would do all of the things.
    Front Sway Bar Bushings
    Revshift 95a Green Motor Mounts
    AKG Steering Rack Kit
    IE Steering Guibo
    VCG
    VCG grommets
    Throw out bearing
    Revshift 95a Green Diff Bushing
    Revshift 95a Green RTABs
    Revshift 95a Green Subframe Bushings
    Mishimoto Radiator
    Metal Impeller Water Pump
    Metal Thermostat Housing
    Mishimoto Silicone Hoses
    Revshift 95a Green Transmission Mounts
    Revshift Poly/Aluminum Guibo
    Oxygen Sensor
    80 degree Thermostat
    82 Degree Fan Switch
    SPAL Fan
    Sport seats
    Coolant
    Paint on all the things
    Garagistic Delrin Shifter bushings
    Garagtistic Clutch and brake pedal bushings
    Throttle Cable
    Injector Rebuild
    Gear Shaft Rod Joint and foam thingy
    Gas Fill Cap Boot
    Garagtistic Billet Throttle Bushings
    Valve Cover Gasket
    Oil Pan Gasket
    Shifter cup
    Clean the whole engine bay
    Remove interior and shampoo everything and clean all the things
    Restore bumper trim and bumper surrounds
    Shift lever washers
    Heater hoses
    Intake gaskets
    Exhaust gaskets
    Z3M shifter
    CSB
    Sport Seats
    Guibo Hardware
    Trailing Arm Hardware
    Rear Strut Hardware
    Throttle Cable Clips
    White car when I first got it
    Put some sweet rimzz on it...lol.
    A week or so before the wreck and about a year after the rimzz
    Reshell canidate
  • brshelton
    • May 2014
    • 102
    Day 1 was a huge day as half the garage was full of junk. We spent 4-6 hours cleaning the garage out and filling the entire yard with junk, sweeping and cleaning, and organizing. After that was done we got the white car into the garage, removed a few things, and drained some from the m20
    Day 2 was a huge day of wrenching. We pulled the m52 and stripped the white car completely except for the differential and axles. We felt pretty accomplished for hitting the 24 hour mark since starting and having the m52 out.
    Day 3 I worked on cleaning the m52 while they worked on getting the m20 ready to pull. We decided we were gonna get the m20 out that night and got to it. Mission was accomplished after using a ratchet strap as a load leveler (stupid massive auto trans) and physically lifting it over the core support for the final bit (lol harbor freight hoist yunolift high). Called it a night after that.
    Days 4-6 have been pretty unproductive. We got the blue out of the garage to powerwash and clean the bay and got the rear end off the white car on day 4. Day 5 and 6 I did some wire harness work at home and a friend wire wheeled the valve cover and we started painting stuff at home in the heat. I also cleaned and rebuilt the injectors. Its been between 10 and 30 degrees with a nasty wind here the past couple of days. I finally broke down and ordered some Carhartt coveralls tonight and paid for overnight shipping. Hopefully tomorrow will start the real work again. I also decided the harness that the PO had hacked up for the original swap was too hacked up and got a new harness and am making an adapter.
    • E30NJ
      • Aug 2013
      • 921
      Sub'd. Love the color. Im about to get a 4 door Schwarz soon.
      • brshelton
        • May 2014
        • 102
        I will be trying to keep up with daily posts. Reread the OP I updated it.
        • brshelton
          • May 2014
          • 102
          Day 7 I didn't do much. Sold a car for a friend and made a sales commision, and bought parts with the money, and sold some parts off the blue car, to also buy parts with the money. I also did some brake pads and a caliper for a friend for some cash, which also went to parts. Ordered what should be the last parts. I also put 2 more coats on the valve cover for a total of 3 now and put 2 coats on one side of the headers. Carhartts get here tomorrow and I will, hopefully, be able to ignore the temperatures and just do work. PS the Jameson was emptied at the end of day 3 when we got the second motor out. I think I'm gonna pour the 8 dollar rum out....
          • slammin.e28
            שמע ישראל
            • 12054
            Such a nice, neat, organized build thread....
            be a shame if someone came in here and...
            tossed things up a bit....
            • CorvallisBMW
              Long Schlong Longhammer
              • 13039
              Love the color of your new car, keep up the good work!
              • ST1G
                • Oct 2012
                • 6690
                That would be a shame.
                • brshelton
                  • May 2014
                  • 102
                  The color was one of the factors in deciding to reshell. It is the same co lo r as my first e30 and one of my favorites.
                  • ncbrock
                    • Nov 2012
                    • 172
                    yoloswag
                    • brshelton
                      • May 2014
                      • 102
                      Day 8 nothing got accomplished. Had a bunch going on today and was waiting on coveralls. Got them just now though. May go seperate transmission and some stuff.
                      • slammin.e28
                        שמע ישראל
                        • 12054
                        Man, this thread is so bold.
                        • ST1G
                          • Oct 2012
                          • 6690
                          Going where no thread has gone before.
                          • brshelton
                            • May 2014
                            • 102
                            Lol makes it easier to find the relevant posts when scrolling through yalls shenanigans ;)
                            • brshelton
                              • May 2014
                              • 102
                              So worldpac sent me the airbag knuckle when I ordered my 87 steering knuckle today.... Apparently they don't sell the non airbag knuckle. Just going to modify the one that is on the car and replace the steering guibo due to lack of fundage issues (non airbag one is 70 more than what I already spent on airbag one and could use the money...)
