Organized all my plastic fasteners. I love these cheepo organizer containers from HF.
Pulled diff apart because I was paranoid that I did something wrong. Turns out it's fine. Still debating whether or not I want to take it apart to install the bolt spacers to adapt the e36 LSD unit's m14 bolt holes to the e30 m12 size.
Currently the LSD unit is installed without the spacers. So the holes are too big for the bolts. Dunno how bad that is...
Cleaned up the whiteboard and made it current.
Pulled radiator, condenser, and installed engine support bar
Parts
Exhaust, driveshaft, diff
Dropped the whole front subframe to get easy access to the oil pan to change the oil pump. Most annoying part is disconnecting the PS and draining the fluid which I had to do anyway to change the pump. I hate ATF.
Unbolt tie rods, control arms, FCAB brackets, steering linkage (mark the position, lock the steering wheel!!) and unbolt PS hoses. Simple.
And I "finished" the gazebo. Still have some finishing touches, but that's basically it.
Turning my full attention back to the car. I want to drive it.
Parts
