Whitney "Vanilla Shake"- 2.9 daily speedbox
  • whitebulat22
    • Apr 2014
    • 330
    I'm whitebulat, and my whole life (since middle school) has led to me buying this car. I had just become a car guy out of nowhere in 7th grade after meeting this beast on the PS2:
    I never ever stopped playing that game, or reading about and asking about cars with my dad the Mercedes engineer. He influenced my taste to be German first with a side of Italian. I had a class with a still friend back then who thought the same way and we decided we should build a racecar. By circumstance we were into BMWs first so we both went home one night to figure out which one to build. The 3 series was obviously the best platform because it was the smallest, and a quick look on wikipedia through all of the generations at the time gave us a quick look at what was out there. Both of us chose to start building (drawing pictures of) E30 M3s knowing we'd be able to get one together because they were old, cheap and simple.
    Now we're both in college with questionable etas and the story switches to the progress of mine. I finally have one!
    Took a decent amount of time in the search and picked it up for an optimistic deal, fairly clean with occasional starting issues and needing alignment. Felt good about the purchase because me and my girlfriend liked the look with the diving boards and the owner was nice, unnecessarily honest and took it to smog on his dime. Where the car scored about 3% as much as bad stuff as the average passing vehicle in every category.
    Having never extensively driven a manual car, let alone an e30, the first Mulholland cruise in this thing was divine. I was finally feeling a lightweight BMW chassis with the signature inline 6, all my very own and as good as I thought it would be. The handling was there, even if a front shock was blown and the tires were all around on their last legs.
    Everything being immediately perfect, of course there has to be some shit or this wouldn't be a real story. Before that run, the brake booster went out on the way home from buying. I had derpy steering without the alignment that was actually improper tie rods and pathetically weak brakes, and I didn't know when the timing belt had last been replaced- the Mulholland trip was one I known I shouldn't have taken but I couldn't stand to baby my baby forever.
    I got away with that one, but soon after got lost and ended up a good 50 miles from home, in a particularly hard area of the 405 to call for help from, just canyons in the Irvine area w/o many street signs. I had been running on reserve for a while and pulled off to look for any recognizable area, couldn't find one and pulled over where I could to call with my limited battery life. It took a lil while but AAA pulled through, Vanilla Shake didn't. At the moment a new problem arose after being given enough gas to go fill up and go home- she wouldn't start. We were both baffled and nothing worked, so my dad had to come all the way down to pick me up from a nearby mechanic. Those guys were very nice and serviced it for free- they thought replacing the CPS would fix the issue and it didn't. We managed to get it home the next day, and it wasn't looking well.
    From the time I had bought it to now it suddenly looked like not a single thing worked right. We brought over friend E30s and home mechanics to have more failed diagnoses and multiple O'Reilly parts such as a brake booster fail after taking many hours to put in. We had been slowly chipping away for months, and it did not produce results.
    Bottom line was I had next to no mechanical experience at the time having just learned to remove a wheel. I had wasted a good chunk of money throwing parts at it friends told me may work and going back and forth diagnosing new things I had broken for good fees at local repair shops. I did what I should've done in the first place. I ran to Long Beach Autohaus, gave them my savings, and they converted Vanilla Shake into a mechanically solid car. Expensive, but thorough, and thus began her
    PUNK PHASE
    Spotted in action on closed roads (not my channel):
    That's more what I was going for. Summary of what's been replaced / done so far:
    CPS, Timing / Water, Brake Booster, Master Cylinder, Tie Rods, alignments, suspension bushings / arms, motor mounts, cluster / odometer, full ignition system besides plugs / coil, all the key relays, Red46 skid plate. Ireland Engineering springs + Konis (at least 4 times playing with the strut assembly and I've still forgotten a specific washer), Mark D chip (thanks guardodoc!), KAmotors intake, Thrush glasspack muffler, maintenance list is longer than my memory.
    Will get around to putting on my poly RTABs, handbrake, rear shocks, diff / subframe mounts on at an undetermined date. Throwing on some new yellow Bosch Merc lights soon (thanks kid8!), and will have to decide which camber plates to get. When that's all sorted out, the engine will be rebuilt or swapped for a fresh one. Power and efficiency are as good as new, oil consumption is at the point where a quart won't last 1000 miles any more though.
    The body and appearance will be given obligatory attention, that front valance which looks fresh has eaten it a few too many times and has actually always been split in the middle- it was mounted by a couple screws from the side when I bought it. Either getting that fixed or replacing and whiting the car out with skirts, rear apron, spoiler, and likely 16x8 Hartage reps by ESM with 205/50 or 225/45 tires.
    Motivation:
    All of this stuff will be coming together to hopefully create a competitive GTS2 car and something to take autoXing, and BMWCCAing. The goal for the rebuild or swap is the most efficient, cheapest, and fresh engine available. Under 3000 CCs for BMWCCA purposes, so the main item I am looking at is either a fresh M20B25 or an I head and higher compression rotating assembly to put on my engine. I am also on the look for aluminum 24v engines. Power is the last factor, I am looking for a non excessive amount. I've always thought power is something you'll just get used to and the real fun is racing around the turns as adults with go-karts do. The purpose of this build is to get me to the track and have an engine that forces me to scavenge tenths by cornering smoothly, but I wouldn't mind the extra grunt to attend a casual hoon every now and then. If anyone is trying to dump something that may help me reach the goal, let me know!
    Now you know our story thus far. I was serious when I said I hadn't ever removed a wheel when I bought this car, and her feisty attitude has fixed that and a half. I've been carefully giving her bits of care and she has been responding more happily each time. Hope it's been somewhat enjoyable to see!
  • kid8
    • Jul 2013
    • 312
    Man, quite the story! Get those yellow lights on, they should look good on your car. Good luck with the build.
    • whitebulat22
      • Apr 2014
      • 330
      I did, and they actually looked a bit funky to me at first. Nothing a little color coordinating with some Borbets couldn't fix though, I'm loving them now:
      Also threw on some GC camber plates to match the Konis and IE3s. They came with the washers I previously failed many times to put on right, now she suddenly has racecar steering again. Won't start atm prob because of fuel pump so looking for the main one to get it going for the next few years.
      Meanwhile I looked at price tags for various powerplants, and decided this one was a great idea:
      Dissecting and cleaning out little stray nuts / mountains of gunk out of the ports.
      With that purchase future plans have changed, probably just a single mass fly conversion on my six'er + a 3.25 diff for the next couple years while I catch up on maintenance / handling and wrangle it around while it's still modest.
      • phreshkid
        • 4655
        I have no idea what you tried to say throughout these posts but good job on the car I think.
        • ST1G
          • Oct 2012
          • 6689
          I'm confused about the giant screen shots.
          Welcome to R3v. I'd suggest the next thing you learn is how to upload photos to flickr.
          I'm glad you pulled the cone filter back inside the hood.
          • whitebulat22
            • Apr 2014
            • 330
            I like E30s so I'm taking it slow with one and entering the car world with it. On the side I'm preparing a V8.
            • whitebulat22
              • Apr 2014
              • 330
              Thing was giving me fits and I've accidentally replaced the entire car. After randomly cutting out every half hour for months I finally found it was an evil ecu and got my markd chip in a good one. This is the only way to have an eta, the torque even was embarrassing as I relived the stock tune struggling up hills in 1st. Now I'm back to climbing city hills in 4th just because it can.
              Got a super cool Zender spoiler from E30_pare:
              And made sense of the timing marks on the V8 to pull the heads and begin cleaning those.
              • 2mAn
                Señior Mod
                • 21017
                so YOU are the person who beat me to the spoiler...
                Simon
                Current Cars:
                -1966 Blue Boat
                -1969 Red VW
                -1986 White BMW
                -2006 Green Thing
                Make R3V Great Again -2020
                • E30_Pare
                  • 7801
                  Yea thats the guy get em!
                  DREWLIENTE
                  1$ PShops PM me
                  • Sh3rpak!ng
                    • Jan 2014
                    • 2667
                    Hey, just sold you the late model shifter carrier
                    Awesome story! I was also obsessed with NFSMW for years and years (I still hang on to a silly dream that one day I will recreate that e46 m3 from the game)
                    Nice progress so far. Seems we have similar goals, though I think mine include more power :P hmu if you ever want to cruise mulholland - it never gets old
                    Shadetree30
                    • whitebulat22
                      • Apr 2014
                      • 330
                      Thanks man! I hope one day you get a hold of a flat plane v8 like the real gtr. Love how it sounds just like this car even in the primitive 05 game. Favorite driving vid of mine. Ive resigned that I wont quite get the engine, but an M60 e30 with straight cut gears... def happening one day.
                      Updates:
                      1. Name has finally been given, she is Whitney.
                      2. After running perfectly for a week, I replaced her intake boot with one that didnt have a giant hole in it. Developed a clueless idle at first, and now misfires at all rpm horribly especially when warm. Capable of rumbling like an sti in neutral. I took care to put everything back where it was before, but here I am and I cant find for the life of me which part is bad, or any evidence against a possible culprit.
                      3. This was after those 4 months of me wondering why it would randomly die in gear on the highway or not start sometimes. I recently obtained this 6th 027 ecu from efficient:
                      to give you an idea of how things have gone since. To recap, ebay chip instantly fried the oem computer, one died sitting in my room between that and its first exposure to mark D, two mark d ecus have failed, and I have 2 more backups I dont want to use.
                      4. She has been very rude in other areas as well. Hood latch broke so i use a screwdriver to open now, rear view mirror and check panel fell out (I was reaching up to hit something for that one), door handle plastic disintegrated, obc fell into the under dash abyss etc. As much as I loved the brief windows of perfection, Id really like to push her off a cliff. Not before some quality time with a hammer. And muttering a bunch of times that I should've gotten a 944.
                      5. Because Ive spent so much time not driving, Ive saved up a lot of money while scavenging secondhand parts from our great community, and now basically own a complete e30 rebuild kit down to every detail. My room now reeks of old top gear, well funded and ambitious, but rubbish:
                      New I head is likely the fix for now. All this effort here for an eta? Almost entirely redone fuel and spark systems for endless intermittent electronic issues and a useless, brain dead computer that has no idea what to tell you when things aren't right? Surely the new problem is also inexpensive and simple to fix, but I'm close to giving up on finding it. Id appreciate if someone came over and broke a head bolt loose, forcing me to go through with the 2.7i upgrade.
                      • Sh3rpak!ng
                        • Jan 2014
                        • 2667
                        HA so do I. It's a dream that I keep in hopes that one day it might have a chance. God damn that's a beautiful sound. I can still hear the cars/engines from that game in my mind... I played it that much.
                        M60 e30 is an excellent attainable alternative
                        Drink a beer, crack that head bolt and get on with it!!
                        also, subbed
                        Shadetree30
                        • whitebulat22
                          • Apr 2014
                          • 330
                          Engine bay with some help from yert315 is now here:
                          Seeing if I can get the last piece down atm, no fuel or spark. I couldn't find any resistance on my crank or cam sensors, nor on ecu pins 47 or 48 where the crank sensor should show up. Since I found nothing anywhere and it should be 500 ohms, I'm flabbergasted because both sensors were just working. I've also been told to investigate the c103 which is not connected.
                          On a bright note, my special someone helped me boil an intake boot to add m30 afm and power.
                          • efficient
                            • Feb 2012
                            • 3312
                            Hey how's your car coming along?
                            • whitebulat22
                              • Apr 2014
                              • 330
                              Running! :p
                              Drove to work today, first time in a while. Nice one mile test drive. Nothing strange has happened, sooner or later once I don't have open headers I can go above 3000 rpm and see the restrictions I've lost.
                              The m30 afm causes it to stutter idle at about 500 rpm at first, the first time the ecu sees it after restart, both with 3.0 and 2.5 bar fpr. It seems to be learning and trending toward 750 now, running better too. I threw in a 2.5 bar fpr to neutralize the m50 injectors, as I found a very rich dyno with the m30 afm / m50 injector combo.
