Semaj4712 - 72 BMW 2002 2.7 M20 Turbo Build Thread
  • rturbo 930
    • Dec 2005
    • 2629
    Awesome project, subbed! And I really like your wife's C10. My dad has a 67 C20 in a similar color scheme, although it looks like someone actually took care of your C10 since it has shiny paint, haha. What's going on with the Model A frame?
    • semaj4712
      • Mar 2012
      • 3069
      Originally posted by ForcedFirebird
      The pistons in the pic of the block show it's a 2.7eta bottom end - also note the oil filter adapter (no oil cooler attachment), the seta and 2.5 use the same 885 head casting, different cam and valve springs. The seta has the piston dome like a 2.5, but in the longer stroke. If you are using the 200 casting head, then it's a complete eta motor.
      You are correct, my mistake that is what I meant, 2.7eta not super eta, i am using the 885 head
      The c10 is a really nice truck, just over 100k on it, original paint with a little patina, we detailed it quite a bit about a year ago, which still seems to be holding up pretty well.
      The model A is something we will probably be starting fairly soon, during the breaks while the 02 is out getting the cage and then again for paint we will start on it fully, weve been collecting quite a bit of parts for it.
      Currently looks like this, but nothing is really bolted together, just sitting on the chasis
      29 Model A // 55 GMC 100 // 66 C10 // 72 BMW 2002 2.7 M20 Turbo // 75 CB500T Custom // 04 BMW M3 // 13 BMW 328i Sport
      72 BMW 2002 2.7 M20 Turbo Build Thread // INSTAGRAM
      Gewerkschaft der Polizei Sticker/Clings For Sale $8
      • itskingsteelo
        • Jul 2013
        • 1340
        wow....just wow.. all the work you do to all these cars is really inspiring. keep up the awesome work. that 02 is gonna be bitchin when its done.
        Originally posted by dvck
        • tak7
          • 856
          That motor is sweet, love the gold!
          All your projects are incredible, keep it up.
            • 37833
            The engine looks great! I can't wait to see this one come together. :D
            Grover Beach, California
            BimmerHeads.com
            • pandaboo911
              • 2070
              you know you're a gearhead when friends and family get in the way of working on your car
              • semaj4712
                • Mar 2012
                • 3069
                Well the good news for me is that my wife is possibly a bigger gear head than I am
                • Mac_86ES
                  • Feb 2013
                  • 21
                  Lucky dog. Mine gets jealous like the cars are other women. Which they kinda are I guess.
                  • efficient
                    • Feb 2012
                    • 3312
                    Nice build. Keep up the good work.
                    Did you modify or redo the welds on the turbo manifold?
                    • semaj4712
                      • Mar 2012
                      • 3069
                      I did not, this is actually the turbo manifold that wobbie had run in his 02, in fact all the turbo parts except my turbo is from him. He has said that he did not have any issues with the manifold when he ran it so I decided to just run it as is.
                      However I picked up a tig welder last week, should be here next week and I figure once I finish everything, a good fun experiment might be making a turbo manifold from scratch, so I may just build my own down the road.
                      • Jeff2886
                        • Nov 2011
                        • 52
                        Awesome projects man!
                        Subbing for more!
                        • Tylerlb
                          • Mar 2015
                          • 1
                          In for more
                          OP you're a madman!
                          • semaj4712
                            • Mar 2012
                            • 3069
                            Got a little bit of time to work on the car today, was hoping to get a lot more done than I did, but o well, progress is progress
                            I got the trans and a dummy block in so that I could make sure my tunnel will clear all around, hoping I have enough room for the slave, took awhile to get the both in there and bolted up since it was just me and no hoist
                            Then there was about 2 hours of getting under the car measuring, climbing back out, cutting etc making the trans brace, I got what I think should work all finished up, now i just need to clean up the welds so it can mount flush and get some holes drilled to bolt it in
                            Should get that mounted tomorrow and hopefully be able to tackle and finish most of the rest of the trans tunnel
                            • semaj4712
                              • Mar 2012
                              • 3069
                              Spent a little time today working more on the trans tunnel
                              The trans tunnel is now constructed for the most part, need to finish connecting it to the fire wall and to the rear of the trans tunnel
                              i was worried I would have to shorten my akg selector rod but it looks like it should clear the ebrake lever, I may look into shortening the ebrake lever 3 or so inches which would then leave me with the same distance between the shifter and ebrake as stoke, well see I have investigate how it works and the ease of shortening it
                              • FL318is
                                • Sep 2006
                                • 1396
                                Looks great. A lot of nice craftsmanship! Color suggestions: Gulf Porsche blue and orange, mintgrun or Porsche Mexican blue
