Garagetotal Kuhfänger
  • CubbyChowder
    • Mar 2012
    • 1487
    #46
    If you do a late model bumper conversion with the rear apron included this will be the best E30
    --Roundie Revival 2.0 - 1973 BMW 2002 Build Thread--
    --Golden Boy E30 Build Thread-- (sold)
    • oprahhwinfreyy
      • Apr 2015
      • 170
      #47
      I kinda want to convert to euro bumpers.
      • CRBR30
        • Apr 2015
        • 234
        #48
        euros would be dope
        '89 325i RoyalBlau Metallic - Kylie
        Follow me on IG! @its.christiannn
        • oprahhwinfreyy
          • Apr 2015
          • 170
          #49
          HQ pics of wheels on.
          • yungmike
            • Jan 2014
            • 281
            #50
            So iceyyyyy mane! And mind disclosing what man-elbow powered procedure you used to clean up your windows?
            • squidmaster
              • Aug 2011
              • 2666
              #51
              :up::up::up::up::up:
              probably my favorite e30 color
              but now you just have to take care of how high up it is
              • Old city bimmer
                • Jun 2014
                • 1114
                #52
                Looks nice
                323i MTEC1
                Z3 coupe
                E60 M5
                • oprahhwinfreyy
                  • Apr 2015
                  • 170
                  #53
                  I used Meguiars quick detailer with a clay bar to get the haze off and then finished off with a window detailer/cleaner and some rain-x
                  • oprahhwinfreyy
                    • Apr 2015
                    • 170
                    #54
                    Finally fixed a trans leak coming form the trans coolant line with the metal hook end. TIP: disconnect the shift linkage and move out of the way. Combine that with a ground down wrench and it works flawlessly.
                    Also cleaned out the filthy airbox as well as service the diff. Other than that just been driving it a little.
                    Also ordered Bilstein front sports and some low stuff.
                    • oprahhwinfreyy
                      • Apr 2015
                      • 170
                      #55
                      Fuck 22mm inner ball joint nuts.
                      • oprahhwinfreyy
                        • Apr 2015
                        • 170
                        #56
                        So today, I've gotten the new rear H&R Super Sports in. Pretty simple, unbolted the bottom shock bolt and the rear sway link, then used a 3' pry bar to remove the old springs. New springs just pushed in by hand.
                        Then, I started on the front. Got everything disconnected from the strut and the struts pulled out and pressure washed in about an hour.
                        Those pesky inner ball joint nuts are awful. I never want to do that again without a lift. Was trying to get them off with a standard length 22mm wrench and a shit ton of penetrating liquid, and just couldn't get enough force to crack the nut loose. After some choice words and a lunch break, I took the sway bar out and it made a world of difference. Had both nuts loose and off the ball joint stud in under 20 minutes. Tedious and slow but good enough with me.
                        I HIGHLY RECOMMEND REMOVING THE SWAY BAR WHEN REMOVING THE INNER NUTS.
                        So now it sits, with everything disconnected except the tie assemblies because with jackstands, I cant get enough room to bend those retaining clip, washer things to be able to thread the inner tie rods out.
                        I'm also waiting on new control arm bushing brackets because the old ones never have had the bushings replaced and they're impossible to remove.
                        I've got the struts in my trunk ready to take to work to use the spring compressor so I can replace the strut inserts and put the new H&R Super Sports in.
                        Canon 5D MKIII / iPhone 5s
                        Canon 50mm F/1.4
                        Natural Light
                        • dpmit94
                          • May 2015
                          • 88
                          #57
                          I'm liking where this is going.
                          '88 325is. built M20. dd.
                          '72 2002 roundie sold
                          Instagram @doug_mitchell
                          • oprahhwinfreyy
                            • Apr 2015
                            • 170
                            #58
                            Don't know how many times now since I've been ordering car parts that I've ordered something and it comes labeled and bagged with the right part numbers yet the part is completely wrong.
                            • spiDmang
                              • 3941
                              #59
                              nice car and documentation!
                              91' 318iS - S54/6MT Swapped
                              08' E90 M3 6MT - Daily
                              Originally posted by IronJoe
                              Originally posted by 2mAn
                              • oprahhwinfreyy
                                • Apr 2015
                                • 170
                                #60
                                After finally receiving the right parts, I've gotten everything put back together and on the ground. Only thing left to do suspension wise is take it to work to a lift and replace the tie rods then align it.
                                For now: Crap Cell Phone Photos
