'91 318is Crack Pipe Edition
  • Bmwdayz
    • Apr 2011
    • 610
    318is never came with premium speakers. So the premium speakers on your package tray were installed later from a previous owner.
    • MusikAffe57
      • Mar 2012
      • 84
      Learn something every day. I have the 675 BMW SOUND SYSTEM option so you're right no premium speakers. Someone must've swapped it out of necessity, because nothing else is upgraded on this e30 haha.
      1991 318is ....... 1985 320i
      1974 R90/6 ...... 2006 Prius
      318is Crack Pipe Edition: Thread
      • MusikAffe57
        • Mar 2012
        • 84
        Floor pan rust
        Today I took care of the surface rust starting under the pedals.
        Sanded with 140 grit
        Primed with Rustoleum Primer
        Painted with Rustoleum Enamel
        I didn't bother masking it. New carpet will cover it up :-)
        • MusikAffe57
          • Mar 2012
          • 84
          Front Bumper Cover removal
          The front bumper cover is toast. So I've got Backtrailzracer selling me an uncracked one. I went ahead and started removing it. Body filler and random wood screws made it a more difficult task than it should've been...
          Bumper Cover off
          The Trim pieces might be up for sale soon. slight wear and damage. Will probably sell for super cheap.
          Also I saved these for someone who might need them for their aftermarket kits. I'll post them in the for sale section.
          And bumper back on for the time being.
          Coming up:
          Euro grill restoration
          Smiley install
          CA Bushings
          • MusikAffe57
            • Mar 2012
            • 84
            Yesterday I swapped the control arm bushings. Having the tools helps but it can still be a PITA
            old one out
            new one going on
            • MusikAffe57
              • Mar 2012
              • 84
              New OEM Carpet Anthracite
              Brand new OEM anthracite carpet just arrived complete with new car smell. Still sorting out sunroof bits before install. picked it up from huskerparts for $645 +$60 for the back panel.
              • stitched
                • Nov 2014
                • 329
                You are really making progress and fast! Good stuff.
                That carpet looks great. I considered the oem replacement, but found a place selling molded carpet for $170-300 depending on options. Still can't beat oem though.
                Keep it up.
                For all inquiries PM me or email: sales@stitchedwheels.com
                ig:stitchedwheels
                • e30s50dan
                  • Nov 2008
                  • 2076
                  Keep up the great work,you will enjoy it when it's all done...
                  NASA
                  BMWCCA member
                  PCA member 25yrs
                  1991 318IS slick top
                  1997 M3 sedan
                  2001 325CI DD
                  “whoever turns the wheel the least, wins"
                  • pandaboo911
                    • 2070
                    $700 carpet for a $1000 e30. Are you sure that crack pipe wasn't yours?
                    • MusikAffe57
                      • Mar 2012
                      • 84
                      haha well since I bought it for $1k it gave me plenty of spending money
                      • MusikAffe57
                        • Mar 2012
                        • 84
                        Keep it up.
                        I considered going with aftermarket, but I was afraid of the fit. That and I didn't want to make it more difficult than it has to be. It'll be better in the long run. pretty much OEM or nothing at all.
                        Thanks. I've been driving beater e30s for so long that I can't wait to have this one all put together.
                        • jrobie79
                          • Mar 2006
                          • 2526
                          1991 318i ---- 308K - retired
                          • MusikAffe57
                            • Mar 2012
                            • 84
                            Sunroof
                            Fixed my broken sunroof. The cable system was completely shattered and missing parts so it required a full swap.
                            Got the parts off of r3v member vpilarrt. Thanks!
                            • MusikAffe57
                              • Mar 2012
                              • 84
                              Window Sills
                              It looks as though someone tried or did break into this car, and in doing so, destroyed the weather stripping. I think the locks are broken, too, but I haven't looked into it. I just can't lock/unlock the car from the doors only the trunk.
                              Looked like this on both sides.
                              Very easy to remove. Simply roll down the window and gently pry from up from the clips.
                              Finished. You have to make sure that you press the seal all the way forward to seal the window.
                              • MusikAffe57
                                • Mar 2012
                                • 84
                                Fuel Filter
                                Went ahead and swapped the fuel filter, oil filter, and topped off the brake fluid and PS ATF fluid. Also, found some more hoses that need to be replaced.
