'91 318is Crack Pipe Edition
  • MusikAffe57
    • Mar 2012
    • 84
    #31
    Euro smileys
    Installed some euro smileys off of sskoda. Still need to make connectors for the city lights.
    Connectors made. Realized that I had smaller connectors on the last pigtail...
    Connected
    Installed. Bolts right up.
    Cleaned up the euro grills, but I still need to paint them. It's been raining too much to get it done.
    Painted bumper. just need to finish it. debating on euro trim now or later.
    1991 318is ....... 1985 320i
    1974 R90/6 ...... 2006 Prius
    318is Crack Pipe Edition: Thread
    • MusikAffe57
      • Mar 2012
      • 84
      #32
      City lights
      Cut the 1/4" male connectors down to a 1/8" connector to fit the side marker plug.
      Wired right up. unfortunately missing the harness for the other one right now.
      • MusikAffe57
        • Mar 2012
        • 84
        #33
        Timesert
        Every valve cover bolt was stripped and glued into place... So begins the TIMESERT. First hole took forever, but it became easy after a couple.
        Also when driving the timesert on the m42, you have too make sure to stop when the driver hits the bottom of the hole. My driver went right through the bottom of a bolt hole...
        Also do I need to re-RTV this or none at all? The last person who worked on this car over torqued everything and put stuff on backwards so I don't know if the m42 really needs it or not.
        • MusikAffe57
          • Mar 2012
          • 84
          #34
          Suspicion confirmed. noisy timing chain. Looks like the sprockets are starting to canoe and become pointy.
          • MusikAffe57
            • Mar 2012
            • 84
            #35
            Refreshed Trim
            Repainted euro grill and trim.
            • jrobie79
              • Mar 2006
              • 2526
              #36
              i have sprockets if you need some...squared off still
              1991 318i ---- 308K - retired
              • MusikAffe57
                • Mar 2012
                • 84
                #37
                pm sent
                • MusikAffe57
                  • Mar 2012
                  • 84
                  #38
                  Euro Grill and Trim install
                  Finished off the stripped valve cover holes. Had to unbolt and push back the upper intake manifold in order to get my drill to fit over the holes. Replaced the gaskets.
                  Installed Euro grills and refurb'd US trim. Just sold a mint condition 2002 dash, so I'll probably use it to buy some euro trim.
                  • MusikAffe57
                    • Mar 2012
                    • 84
                    #39
                    Gimp
                    Just playing with a photo editor.
                    • MusikAffe57
                      • Mar 2012
                      • 84
                      #40
                      Turd polishing
                      1 coat rubbing compound and 2 coats wax with the $20 orbital buffer from walmart.
                      • MusikAffe57
                        • Mar 2012
                        • 84
                        #41
                        Reverse light harness
                        Reverse light wiring was split in half and the live side was touching the exhaust shorting fuse #21. Easy fix, but you can replace the harness with p/n 23141220263.
                        Spliced in some new wire with solderless connectors and wrapped.
                        Reverse lights working
                        Now to repair the euro clock and probably the tach that the loose wire shorted...
                        • CorvallisBMW
                          Long Schlong Longhammer
                          • 13039
                          #42
                          Quick tidbit of advice: rubbing compound is far too aggressive for most automotive paints. Try a medium-cut polish, then a fine polish, then wax. You'll get much better results that look less cloudy, and won't run as much risk of damaging the paint.
                          • MusikAffe57
                            • Mar 2012
                            • 84
                            #43
                            ok I'll give it a try
                            • MusikAffe57
                              • Mar 2012
                              • 84
                              #44
                              Euro analog clock wiring
                              Installed the wiring harness for a euro clock.
                              Harness Pinout:
                              30....31g.31.58k
                              • MusikAffe57
                                • Mar 2012
                                • 84
                                #45
