88' 325 Supereta Track Day Bro - M60 TIME!
  • dasmanschaft012
    • Apr 2014
    • 642
    #46
    Originally posted by paynemw
    Hey - whatever site your hosting your pix in is messing with you. I was looking forward to the M60 deets, but no joy on pictures. Keep up the work man. I feel the same way about my build thread... Good luck man
    thanks for the heads up, imgur was being weird earlier and i tried google pictures. no go. back to imgur, lemme know if any still dont show up
    We're in deep now boys
    1988 325i SETA - Daily driver
    1988 340iL - Track car
    My M60 V8 swap thread here
    [oo==OO==oo]
    • dasmanschaft012
      • Apr 2014
      • 642
      #47
      The last post happened in February, still catching up on updated. Took a break for a week or two to do some other stuff.
      Headgasket on the 240 after it blew at Buttonwillow. Pretty much done gripping with the s13, back to full drift duty. Don't use cheap chinese head gaskets...
      Working on a side project for my roomates 135, mocking up some brackets to CAD out for his upgraded oil cooler. We had a welded steel version, these will be water jetted aluminum. Once the we're done tweaking the brackets, these kits will be on sale for e8x/e9x N54/55 135i and 335i.
      Daud also got some stickers for our group made. Came out pretty well. They are for sale, but no one here cares lol.
      And next weekend, another
      at Streets of Willow.
      [oo==OO==oo]
      • dasmanschaft012
        • Apr 2014
        • 642
        #48
        Timing
        Still catching up on updates.
        Took off the brand new water pump that came with the motor. It does indeed look brand new. However, the savage who put it on siliconed the pump on instead of using the gasket, AND siliconed on top of the old water pipe orings.
        So I spent about 30min cleaning all the off and replaced the orings with new ones.:-?
        I also inspected the 5 speed e34 transmission that came with the motor. A nub had been cracked off and glued back on. Probably will be fine, but this will be my spare transmission.
        So with most of the easy stuff taken apart, i started to turn to the timing system. Upper covers taken off, pretty nasty build up.
        The guides i could see from the upper case looked good
        But since my slogan for this build is "do it right once" I will be replacing the main guides and chain. The upper chains are too much of a pain and look fine. Plus if those break its not as big of a deal as the lower guides.
        Then, it took me about 2 weeks to get the jesus bolt off. 700ft-lb impact couldnt take it off. So I bought the crank tool. Since my engine stand is near the limit of the motor, I attached the hoist for additional support.
        Set up:
        First 1/2" breaker bar with jack handles as cheater cars:
        Second 1/2" breaker bar with 10ft steel thick wall pipe as cheater bar:
        I tried torching the bolt really hot through all this as well. Then i tried a bigger impact gun. And then i tried drilling the head of the bolt out.
        FINALLY, with the crank holder pushing on the ground, a 3/4" drive breaker bar, a 10ft pipe, and 15min of heating it:
        Thank goodness. More catching up to do soon.
        [oo==OO==oo]
        • ArtFoodBMW
          • Feb 2014
          • 765
          #49
          Excited to see where this goes!
          Also, F*** those jesus bolts.
          • jpod999
            • Dec 2015
            • 1401
            #50
            Welcome to the 32v world, start a thread in the V8 swap section!
            OBDI M62B44/6 swap
            Transaction feedback
            - jpod999
            • dasmanschaft012
              • Apr 2014
              • 642
              #51
              Thanks! I'll probably put more of this detailed stuff in a thread there and then make this thread a little more storyish.
              [oo==OO==oo]
              • dasmanschaft012
                • Apr 2014
                • 642
                #52
                I've started a thread for some more of the details on this swap in the V8 subforum.
                [oo==OO==oo]
                • paynemw
                  • Dec 2015
                  • 439
                  #53
                  awesome!! This is cool and I like the fact that you're going bigger than 24v! I suppose tons of body stiffing is required
                  • Jb325is
                    • 2137
                    #54
                    Cool! Good to see more M60 cars being built, that's a really nice combo.
                    That splitter, just no.
                    - '88 m54 coupe
                    <3
                    • dasmanschaft012
                      • Apr 2014
                      • 642
                      #55
                      Valve covers painted
                      [oo==OO==oo]
                      • dasmanschaft012
                        • Apr 2014
                        • 642
                        #56
                        My ride for this afternoon. Freshly detailed. No its not mine ;(
                        [oo==OO==oo]
                        • dasmanschaft012
                          • Apr 2014
                          • 642
                          #57
                          Aaaaaaaaand awaaaaay we go!
                          [oo==OO==oo]
                          • dasmanschaft012
                            • Apr 2014
                            • 642
                            #58
                            Got the core support out. One of the things i've been worrying about, as I haven't cut one out before
                            And we got some new headlights for the 240 so that we dont die at night
                            [oo==OO==oo]
                            • jpod999
                              • Dec 2015
                              • 1401
                              #59
                              Cutting out the core support is totally worth it, way easier to get the engine and tranny in/out!
                              OBDI M62B44/6 swap
                              - jpod999
                              • dasmanschaft012
                                • Apr 2014
                                • 642
                                #60
                                thats what everyone, including matt at garagistic, has suggested. a little stressful cutting it out, but it should be pretty easy to put back
                                [oo==OO==oo]
