Cammed LS1 E28 Build
  • jakeb
    • 1909
    This build has been going for awhile and is actually almost done but wanted to put together a build thread.
    I should have taken some pictures before it was painted...it was tiaga (2002 color).
    Went back to Lach
    All torn apart, VERY clean on the underside
    Reinforced front sub frame steering box mount.
    Then sent out for powder coat...love a big pile of freshly coated parts
    Parts ready to go out to power coat.
    Cleaning up the engine bay
    Painted wheel wells and all new suspension. H&R sports and billys.
    [img]https://lh3.googleusercontent.com/-NMhxz6TrtZI/VOCgIeyUP9I/AAAAAAAASxk/rCfZydqMnps/s640-Ic42/IMG_3204.JPG/img]
    New firewall insulation
    Completely rebuilt rear subframe and 3.25LSD
    Got some e34 535 rear brakes....repowder coated.
    And some massive front brembos
    The plan was to put a used LS1 into it after installing a cam but we found that the first cam lobe and lifter was toast. Also bearings were pretty well gone.
    So...engine came all apart, new pistons, rings, bearings, all seals, 243 LS6 heads, and 228R cam, LS7 lifters
    LS6 intake
    belt drive all installed
    Remote bleeder and new slave intalled on t56
    Modified 98 fbody manifolds
    Painted with VHT flame Proof paint
    In it goes
    Exhaust coming together, 2.5" off manifolds, magnaflow cats, spintech muffler, into magnaflow muffler. Will have a dual out tip (no pic yet)
    AC condenser, radiator etc, going in.
    More coming soon...
    Engine is all wired, fuel system is done, front and rear bumpers are back on, heater hoses all done, VERY close to running and driving.
    www.classicdaily.net
    1970 m42 swapped 2002
    1985 LS1/T56 Swapped e28 (557e)
    www.blunttech.com - For all your parts needs
    Follow me on Instagram for constant build updates @classicdaily
    https://www.facebook.com/ClassicDailyLLC
  • Alpina
    • Oct 2004
    • 838
    Absolutely ,,, FANTASTIC,,,,,,,, more than that even!!
    i am on my way to do this on an E30,, will use 325 as donor,, but with LS and T56
    IMO the LSx is the best engine combo ever built,, amazing engine,, very compact ,,LOT of power available,, for very low cost,, all kinds of parts that cost SO LITTLE,,
    i like the ambitious in your work,, cleaning,, painting,, etc etc... no hillbilly work
    WELL DONE !!!!!!
    Sveinbjörn Hrafnsson
    E30 CABRIO V12 M70B50 ///
    ALPINA B10 BITURBO 346 @ 507
    E34 550 V12 JML
    Finnish wisdom : If you want to Win,, hire a Finn
    http://alpina.123.is/pictures/
    • marshallnoise
      • Sep 2013
      • 3148
      In. Those Spintech mufflers sound wicked.
      Si vis pacem, para bellum.
      New Hawtness: 1995 540i/6 Claptrap
      Defunct too: Cirrusblau m30 Project
      Defunct (sold): Alta Vista
      79 Bronco SHTF Build
      • jakeb
        • 1909
        Yes they sure do
        • Sh3rpak!ng
          • Jan 2014
          • 2667
          Oh my good god.
          That sound coming from an e28... that will give you goosebumps
          Shadetree30
