Cosmosblau 1985 318i slowly but surely
  • E30budget
    • Mar 2015
    • 519
    4 year member and on my 6th E30... Hopefully this one is here to stay (some of you get that) lol
    I picked up a 1985 318i Cosmosblau Metallic coupe 5mt with blue checkered interior for $1300 in WDC
    Mechanically its pretty sound and 98% rust free
    It needs all new bushings and suspension as most of it has surface rust and is sloppy as all hell..
    So here are some pictures so far..
    Paint will remain shitty for a while
    I still need to order seat brackets for the Corbeau GTS II seats and clean them
    I have already ordered:
    Suede shift/ebrake boots
    Nardi Steering wheel (not the classic)
    Solid Condor rear bushing set
    Cosmo coilover kit
    22mm front sway bar
    Dash mat
    Bare rear subframe for disk conversion
    Nardi (not the classic)
    Things I need asap:
    OEM radio
    RTA's
    Front strut tubes 51mm
    Bilsteins or Koni's
    Smoked DEPO smileys
    Windshield front and rear black lock strips
    Motor and trans mounts
    Euro bumpers (eventually)
  • E30budget
    • Mar 2015
    • 519
    So I got the car in air ready to drop suspension and subframe. Still need to buy new brakes for the front and rear, and find a place to have the trailing arms, LCA's, and subframe blasted clean of all surface rust, also need bilsteins and new shock mounts..
    Also ordered ANSA cat back from another member for $50, poly alternator bushings as mine are shot, euro HVAC panel, OE radio (had a blaupunkt before), suede shift boot and e-brake boot kit
    Some parts arrived today :)
    Cosmo coilover kit 8k 6" front springs and 10k 5" rear springs
    22mm front sway bar
    new control arms with ball joints, tie rods, and sway bar links
    Condor subframe, RTA's, diff, and offset CAB's
    Outer front window seals
    Should be an eventful few days doing the overhaul, waiting until I order the other parts I need stated above
    PICS!
    • Reichart12
      • Aug 2012
      • 2165
      Nice pack of suspension goodies. What part of Maryland are you in?
      Instagram: Reichart12
      • E30budget
        • Mar 2015
        • 519
        Im in Annapolis/Davidsonville area! Shoot me a text we can get up one day and talk E30 lol 410-212-5360
        • E30budget
          • Mar 2015
          • 519
          Scored an ANSA Cat back and STAHL Headers for a total of $125 :)
          • fresh_TD
            • Aug 2013
            • 2457
            Good score on the headers and exhaust!
            Sent from my Samsung Note 4
            '91 318i (Alpine) - daily
            '88 325ix (Zinno) - drive here and there!
            • E30budget
              • Mar 2015
              • 519
              Thanks, im now looking for a set of used Koni front inserts so I can begin the coilover install
              • fresh_TD
                • Aug 2013
                • 2457
                What coilovers you go with?
                • E30budget
                  • Mar 2015
                  • 519
                  Cosmo coilover kit 8k front and 10k rear :)
                  • E30budget
                    • Mar 2015
                    • 519
                    Before I go any further, I just want to let yall know that rust is my biggest pet peeve, I hate everything about it and the way it lives :(
                    So today I finished going shadow line, pulled my door seals and plastics and found some rust under the pass. side door sill, I ground it down to bare and hit it with etching primer until I can decide what to do with this...
                    There was also a spot on the driver rocker so I ground that down as well then too a step back and it looked ridiculous with the big smooth spot, so I began to grind all the rock guard off each rocker, spray with etching primer then will go over with a gloss black rustoleum..
                    I also got around to installing my shift/ebrake boots from "Matt-B" and my euro HVAC panel I got from another r3ver :)
                    While doing the shadow line job I pulled the door trim to install new window seals from Turner as mine were dried out and cracked
                    PICTURES!!!!
                    • 2mAn
                      Señior Mod
                      • 21031
                      I hope you arent planning on selling that header!?
                      Build this thing up and it should be fun.
                      Simon
                      Current Cars:
                      -1966 Blue Boat
                      -1969 Red VW
                      -1986 White BMW
                      -2006 Green Thing
                      Make R3V Great Again -2020
                      • 5Toes
                        • 9836
                        Love it! Had the same car I bought from an old dude in th emiddle of nowhere.. mine barely ran and had loads of rust - ended up parting it out. cosmoblau rocks though, love seeing the color on my brothers e28!!! sub'd
                        • spiDmang
                          • 3941
                          I have a soft spot for cosmosblau E30's...i had an S50 swapped cosmosblau sedan a couple years ago when i was in college.
                          Keep up the progress!
                          91' 318iS - S54/6MT Swapped
                          08' E90 M3 6MT - Daily
                          Originally posted by IronJoe
                          Originally posted by 2mAn
                          • E30budget
                            • Mar 2015
                            • 519
                            Ran into a few problems with the new alternator today, causing an extreme short and battery drainage... Need to source another alternator pronto so I can start driving this darn thing again
                            • 2mAn
                              Señior Mod
                              • 21031
                              Look at you sounding like a grown up and shit.. :rofl:
                              OP there's a ton of alternators out there. Are you sure that's what's wrong? Might be the voltage regulator
                              Simon
                              Current Cars:
                              -1966 Blue Boat
                              -1969 Red VW
                              -1986 White BMW
                              -2006 Green Thing
