Project Lessmeister: 91 318iS Restomod w/ MTech2 and modern drivetrain
  • CorvallisBMW
    Long Schlong Longhammer
    • 13039
    #661
    Where's the radiator?
    • dsphil
      • 495
      #662
      It's a custom air cool m54 with fan delete.
      327is
      325es
      325es
      318is
      Fiesta ST
      E46 M3
      • Jordan
        • 12907
        #663
        Radiator is back in the car now, I had it out for access to something else.
        https://mtechniqueabs.com/
        • Bimmer_man
          • Jan 2013
          • 1477
          #664
          That intake box you have is it designed to clear the ABS unit there or dose that have to be deleted to install?
          Float like a cadillac sting like a Bimmer!:)
          • fresh_TD
            • Aug 2013
            • 2457
            #665
            It's designed to clear the ABS unit.
            Sent from my SAMSUNG-SM-N910A using Tapatalk
            '91 318i (Alpine) - daily
            '88 325ix (Zinno) - drive here and there!
            • Bimmer_man
              • Jan 2013
              • 1477
              #666
              oh sweet thanks. BTW Jordan the car looks awesome.
              • litu
                • 816
                #667
                Cool project
                https://www.facebook.com/Cry_77_IX-110483784967661
                https://www.instagram.com/cry_77_ix/
                • wark
                  • Jul 2013
                  • 321
                  #668
                  Hey Jordan, another question for you. I picked up a few cans of the SEM trim paint, what kind of prep did you do for that? Any primer? Sanding?
                  Dustin Wark | Instagram tumblrFlickr
                  • Jordan
                    • 12907
                    #669
                    Originally posted by Jordan
                    I painted them all with SEM Trim Black #39143. This is the best product out there for this finish period. It is the industry standard for a reason.
                    On the metalwork you will want to completely sand off the clear finish on the aluminum trim. Do not paint over the clear and expect the paint to get a good bite, it will chip from road debris easily.
                    Sand it with 120 until you've removed all of the clear. The surface feel/texture changes considerably once you've broken through and you'll know. Then step up to 220, and finish with 320.
                    SEM Trim Black will cover 320 sanding scratches in the 2-3 coats you should apply.
                    Thoroughly clean the parts with dish soap/water, or paint prep solvent.
                    I laid out the parts on stands or on a large cardboard box with balled up masking tape (sticky side out) as standoffs from the box. This lets you blow paint under the edges and such with ease, and since the tape is sticky it keeps the part from shifting.
                    First coat should be just a dusting. You aren't trying to get concealment just dust the parts to provide a better bite for the next coats. After a few minutes do a second coat and try for almost full coverage, but you should still be able to see through the finish.
                    The third and final coat should give complete coverage. Allow to dry in the sun for an hour then install your parts.
                    Nothing really worth taking pictures of going on the last few evenings. Routing wires, troubleshooting oil pressure lamp circuit (fixed) and working on radiator hose fabrication. I found a perfect molded hose from a late model BMW for the upper, but I'm still struggling to find something I'm happy with for the lower.
                    • wark
                      • Jul 2013
                      • 321
                      #670
                      Awesome, thanks. What about with plastic pieces? Grilles, license plate filler, etc?
                      • Jordan
                        • 12907
                        #671
                        On plastic you can usually do prep with a maroon scotchbrite pad, followed by a thorough cleaning.
                        • spdlmtna
                          • Mar 2016
                          • 2
                          #672
                          I see you are using OBDII, and I'm not sure if you have a catalytic converter in that exhaust piping, but if this was put through an emissions test, do you think it would pass similar to the engine's donor vehicle?
                          The build is looking awesome!
                          Thank you
                          • Jordan
                            • 12907
                            #673
                            The catalysts are from a F10 535i, rated at a higher capacity than the ones on a NA M54b30 no doubt. I have very little concern that it would not pass a tail pipe test.
                            Would it meet all of California's ridiculous laws regarding swaps and such? No idea, but probably not knowing CA.
                            • wilholl
                              • May 2012
                              • 518
                              #674
                              Have to be California approved convertors with part number specific to make, model and year of car. So, probably not.
                              1988 325 non-letter Seta "Bronzit"
                              1991 325ic "Laguna Green" (Sold)
                              1993 325i "Laguna Green/Silver" (Sold)
                              1998 528i "Artic Silver" m-sport(totalled by drunk driver)
                              2000 528i Titansilber/gray m-sport
                              2000 528i Titansilber/black m-sport(sold)
                              2001 525i Anthracite m-sport(sold)
                              2013 750i Black/Black m-sport "Beast"
                              • Jordan
                                • 12907
                                #675
                                First actual run in of Project Lessmeister. Warmed up to operating temperature and rapped out.
                                Camera (iPhone6) can't even deal.
                                Catback fabricating coming this weekend.
                                Subwoofer highly recommended.
