Project Lessmeister: 91 318iS Restomod w/ MTech2 and modern drivetrain
  • JeLani
    • Aug 2015
    • 1552
    #646
    Sent from my payphone using Tapatalk
    1986 LTW M52 (First project 2015- )
    1998 e36 328ic/5 -
    Roundie alpina pig cheek’d (1969)
    1967 2002 parts car
    1994 318iS junked.
    • Jordan
      • 12907
      #647
      Originally posted by stonea
      Good lord that sounds nice.
      That is dumping out under the car after the cats and resonator, I haven't fabricated the cat back section into the Remus yet. Its pretty quiet too all things considered.
      https://mtechniqueabs.com/
      • fresh_TD
        • Aug 2013
        • 2457
        #648
        What was the issue?
        Sent from my SAMSUNG-SM-N910A using Tapatalk
        '91 318i (Alpine) - daily
        '88 325ix (Zinno) - drive here and there!
        • bradnic
          • Jul 2012
          • 3550
          #649
          same q. whatever it was you solved it fast man.
          HOWTOs:
          DB vert plastic bumpers
          OEM Keys
          MTech1 docs
          88 ix Lach/Card
          91 ic Calypso 3.1
          86 Cosmo 2.7
          OEM+ or bust!
          • Jordan
            • 12907
            #650
            I'm not exactly sure what was wrong, I noticed some really odd codes when I actually looked at them like a "device error" and the ICV wouldn't go to sleep after a start attempt unless I disconnected the battery.
            I couldn't hear the ICV earlier because I had tunes jamming.
            Mark suggested I try flashing the DME again. Pulled it out, flashed it again and voila... She started right up and no more ghost ICV.
            • Mr. Wolfe
              • Jul 2014
              • 540
              #651
              Oh hell yeah. That engine sounds incredible!
              Mr. Wolfe
              • flyboyx
                • 8371
                #652
                real nice!!! awesome! true milestone there.
                Gigitty Gigitty!!!!
                • faujijatt
                  • Aug 2015
                  • 132
                  #653
                  Good lord, music to my ears, that is.
                  Sent from my SM-N920V using Tapatalk
                  • jeenyus
                    • Aug 2011
                    • 2064
                    #654
                    yea that sounds amazing.
                    • kronus
                      • Apr 2008
                      • 13014
                      #655
                      nice. congrats!
                      cars beep boop
                        • 37827
                        #656
                        Awesome!
                        Classic BMW Specialists
                        Santa Clarita, CA
                        www.BimmerHeads.com
                        • Jordan
                          • 12907
                          #657
                          The engine is all buttoned up again except for the radiator. Firewall covers installed and looking clean. All of the wiring fits no problem under the covers, actually a lot less of it than with a E36 M/S5x swap. The main wiring cover also clears the engine/manifold with room to spare, where as the OBDI E36 M/S5x manifold requires you to trim the covers.
                          Last night I had the fuel pump manually jumped as I had not yet wired in a fuel pump relay. This evening I went ahead and did than, then wrapped all the wiring with the same OE loom tape before fastening it to the backing plate with zip ties and installing the covers. The fuel pump relay coil is grounded by the ECU to activate the fuel pump. The coil is fed with switched 12v, and the drive side is fed with a constant 12v just as it is in a native MS43 vehicle.
                          Engine wiring with fuel pump relay:
                          • bradnic
                            • Jul 2012
                            • 3550
                            #658
                            that's incredibly CLEAN. art.
                            you should up your price.
                            HOWTOs:
                            OEM Keys
                            MTech1 docs
                            88 ix Lach/Card
                            91 ic Calypso 3.1
                            86 Cosmo 2.7
                            OEM+ or bust!
                              • 37827
                              #659
                              Engine bay looking good! I vote you shave the spot for the diagnostic plug off the wiring bracket though. ;)
                              Santa Clarita, CA
                              www.BimmerHeads.com
                              • s14brent
                                • Mar 2014
                                • 534
                                #660
                                Super clean engine bay! Love the tool box setup you got going on too!
                                89 325i 4dr s52
                                02 BMW 525iT m54b30/manual swapped (daily) *sold in 2020 repurchased in 2025*
                                21' Toyota Tacoma TRD OR 4x4 6 speed Manual
