M52/Zf Alpine White 1986 E30
  • e30austin
    • 15382
    #151
    You are far more ambitious than I. Best of luck to you.
    • JeLani
      • Aug 2015
      • 1552
      #152
      Means alot man ! I take it you saw the pics on the thread .
      1986 LTW M52 (First project 2015- )
      1998 e36 328ic/5 -
      Roundie alpina pig cheek’d (1969)
      1967 2002 parts car
      1994 318iS junked.
      • JeLani
        • Aug 2015
        • 1552
        #153
        18 Y.O. Learns bad investment :AW 1986 M52 swap thread (E36 content as well)
        Friend couldn’t buy the e30 , driveway too full .. where we are now :
        Copped a pair for a steal . Easy to fit in e30 just need to flatten where the stud goes in all around , these curve about 70 degrees downwards.
        Next purchase will be a zf and driveshaft. I have what I believe is a m20 single mass flywheel to go with that.
        As for the 02 , found a shell thats been blasted primed and caged . Price and of preparing this tub would be triple the price of the shell I found . Worked on getting ready to pull the m10 and 4-speed this afternoon . Good progress. Comes out and 4 speed swap will be for sale.
        Some goodies :
        Rebuilt italian weber 45 DCOE, OEM intake manifold and custom cast velocity stacks.
        1998 e36 328ic/5 -
        1967 2002 parts car
        1994 318iS junked.
        • JeLani
          • Aug 2015
          • 1552
          #154
          Pick and pull had a deal today :
          First time pulling a trans alone , with great success . Zf from a 1998 328i sedan . Picked up the crossmember as well . -$135
          1998 e36 328ic/5 -
          1967 2002 parts car
          1994 318iS junked.
          • JeLani
            • Aug 2015
            • 1552
            #155
            Remaining stuff for the swap . Not too much left . I estimate $6-900 later . Clutch kit and flywheel work may run most of that amount , it’s a 228mm m20 single mass , looking into sachs HD kit or clutchmasters . Also would like to change out the input and output shaft seals and detents on the zf , and found a zf front propshaft on here so I’m going to grab that soon .
            Any fuel pump recommendations ? My inline was replaced by me years ago , but my outer one has probably never been replaced which may cause me problems , what do you guys run for fuel filters in the 24v realm?
            1998 e36 328ic/5 -
            1967 2002 parts car
            1994 318iS junked.
            • JeLani
              • Aug 2015
              • 1552
              #156
              2002 manual swap for sale soon . Differential , pedals , and driveshaft still in the car.
              1998 e36 328ic/5 -
              1967 2002 parts car
              1994 318iS junked.
              • efficient
                • Feb 2012
                • 3312
                #157
                why are your pics so blurry? clean the lense maybe?
                • JeLani
                  • Aug 2015
                  • 1552
                  #158
                  I need a new phone , lens glass broke then the lens got damaged :/
                  1998 e36 328ic/5 -
                  1967 2002 parts car
                  1994 318iS junked.
                  • JeLani
                    • Aug 2015
                    • 1552
                    #159
                    Current story on the e10 . Awaiting delivery on this roundie shell that is caged and paint ready . Need to pull the rest of the parts from the first shell , then this thing will be stored until garage is safe and organized enough , while it is away for paint I will finish the swap. Shell is already prepared for fiberglass Alpina pigcheeks already . Rust free car here ! :)
                    The old caged shell from idaho is worth:
                    M10
                    4 speed
                    Pedals
                    Whats left of wiring
                    Brake booster
                    Driveshaft
                    Diff
                    Pedal set
                    Steering wheel
                    dash
                    Cluster
                    Doors
                    E brake assembly
                    For $1.4k taking into account $500 plus shipping from boise , not bad on all the parts . Will be 5 speed swapping it , having m10 rebuilt and probably stroked 2.3l . More on that later , just a teaser .
                    1998 e36 328ic/5 -
                    1967 2002 parts car
                    1994 318iS junked.
                    • wworm
                      • Dec 2016
                      • 1719
                      #160
                      s14 crank?
                      1984 Delphin 318i 2 door
                      • JeLani
                        • Aug 2015
                        • 1552
                        #161
                        Originally posted by wworm
                        s14 crank?
                        Yes , 92mm m30 pistons , rods gotta do my research about . As well as the rest of the stuff , 92mm bore should be safe for an m10 block.
                        1998 e36 328ic/5 -
                        1967 2002 parts car
                        1994 318iS junked.
                        • JeLani
                          • Aug 2015
                          • 1552
                          #162
                          1998 e36 328ic/5 -
                          1967 2002 parts car
                          1994 318iS junked.
                          • JeLani
                            • Aug 2015
                            • 1552
                            #163
                            I’m kind of over this thread . I want to make a new one when i get another phone .. or whenever . The 318iS turned into a 328i and a vert in one day . Sold to junkyard , and friend with no license had this vert sitting outside of his house since december . Has a straight piped muffler delete from the mid-section- back . 160k miles , dove grey interior , runs fine , going to do all of the routine maintenance though. Sold the grey coupe to the junkyard for the same amount of money i paid for the vert . Which if you can imagine is very little. Clean title by the way.
                            In this picture , the sr was disconnected from the trans , it has since been fitted with a clip . I was replacing the shift boot and when I went to pull the knob off it disconnected ... took all of 5 minutes to replace.
                            Kept my red tails from the coupe.
                            1998 e36 328ic/5 -
                            1967 2002 parts car
                            1994 318iS junked.
                            • 2mAn
                              Señior Mod
                              • 21062
                              #164
                              Just edit the title of the thread and keep the sh!t show going lol
                              Simon
                              Current Cars:
                              -1966 Blue Boat
                              -1969 Red VW
                              -1986 White BMW
                              -2006 Green Thing
                              Make R3V Great Again -2020
                              • jeenyus
                                • Aug 2011
                                • 2064
                                #165
                                So which car are we on now? Re-title it to Car-Carousel or Russian-Roulette.
