Yeah, I'll of course use new hardware when assembling the ring gear and the LSD unit. I think I'll go with two plate pairs as in original. I was thinking it might be possible to flip over the dog plates because the other side is fairly virgin. Is there any reason I shouldn't do that?
					Project Armo "330i" M-tech 1
No reason I can think of. Ofcourse if you look at the factory repair manual it says replace all worn/scraped parts. Did you measure the slip torque of the LSD before taking apart? Stock value for new parts is ~45Nm, and yours might have less.. I did one diff on a budget, to a friend of mine. We put in 3 pairs of used plates in, all stock thickness. Selected the least worn 3 from a pile.. That ended up having 100Nm of initial slip torque.Yeah, I'll of corse use new hardware when assembling the ring gear and the LSD unit. I think I'll go with two plate pairs as in original. I was thinking it might be possible to flip over the dog plates because the other side is fairly virgin. Is there any reason I shouldn't do that?
My own has 140Nms. Your car will be way more powerful and with grippier tyres. Just food for thought. :)
JarnoComment
I didn't remember to measure the breakaway torque before disassembling the diff. You have very valid points. The car will also have wider tires and more torque than stock 325i or 325e. Jannmann on another forum raised also a good point about more discs equalling more durability and less wear per disc. I might look into building a three or four disc unit after all.No reason I can think of. Ofcourse if you look at the factory repair manual it says replace all worn/scraped parts. Did you measure the slip torque of the LSD before taking apart? Stock value for new parts is ~45Nm, and yours might have less.. I did one diff on a budget, to a friend of mine. We put in 3 pairs of used plates in, all stock thickness. Selected the least worn 3 from a pile.. That ended up having 100Nm of initial slip torque.
JarnoLast edited by Skarpa; 05-29-2016, 07:19 PM.Comment
A lot of tedious preparation work goes down again. In the past Armo has been "rust-protected" meaning that there's this annoying, black, tarry gunk everywhere on the underside of the car. I hate it and want to get rid of it. In the end I'll apply new layer of 3M sprayaple sealer 08800 and paint the underside of the car zinnoberrot. In most of the places new stone guard would actually not be necessary because the factory stuff is just fine. It's just that it's nearly impossible to remove only the black stuff and leave the factory sealer and paint. You can wash it away with paint thinner or petrol but it takes gallons of that stuff and alot of rubbing so I've found it easier to just remove everything and start fresh. Nowadays I use grinder and steel wire wheel for removing. It produces a lot of mess but works well and if you do it carefully you can actually leave the original body primer pretty much untouched.
Before coming to this conclusion I tried various methods of removal including blow torch and a chisel. That worked also quite well but it was a bit difficult with more complex shapes and the chisel tended to leave nicks in the surface. Drivers side wheel well is where I experimented with different methods before moving to other things. It had been exposed to air humidity for past four years and the chisel nicks had developed into rust spots so I had to clean it up and treat it with phosphoric acid and nylon wheel to get rid of the surface rust.
The rear corner had some more rust so I replace a piece and also welded a couple of holes shut.
Then I painted the wheel well and the inside of the wheel arch and a few other places where I had worked as well.
The spare wheel well is not actually rusty. There's just loose steel dust from grinding that has rusted and coloured the surface. I need to clean up stuff like that before final painting.
And then for something completely different:
I have strange tendency to make things more complicated for myself than they actually need to be. I had perfectly fine transmission with suitable drive shaft, shifter linkage, flywheel, clutch and rear bracket. I decided to sell it and now I'm in search of one that will require modifications to all those things and also a new clutch friction plate. Makes perfect sense. To be more exact I'm searching for a six speed gearbox from a 330i or more likely from a newer four banger diesel engine since they are about half the price. Diesel engines have the same tilting angle as M20 so the gearbox will sit tilted and will require modification for shift linkage and the rear bracket. GS6-37DZ transmission has a shorter clutch shaft because the pilot bearing is located at the flywheel in those engines. Also it has a finer bore of 26x29-22N. I will most likely fabricate extension for the clutch shaft so before I parted with the 5-speed ZF I made measurements of the pilot bearing shaft location.
I realized only later that I could also have measured the total length of the transmission from bell housing flange to output shaft flange to know exactly how much I need to shorten the drive shaft but I'm sure I'll find that information somewhere or just test-fit and measure it when I have the new tranny.Last edited by Skarpa; 08-09-2017, 08:59 PM.Comment
I cut the drivers side wheel arch in shape. Now the wheel arches are pretty much ready to glue and I borrowed the arch roller for the job so I think I'll try to do that on Sunday.
I also removed the sealer and the surface rust from the rear edge and the underside of the trunk floor and was satisfied to see that it's in decent shape. There's a rust hole where the trailer coupling cable went through the rear face. Also the rear end of the frame beam will require some attention.
There's rust under the rear flange so I think I'll remove it, clean it and weld it back. The screws for the heat shield have rusted away but otherwise the frame beam seems to be solid.
Yesterday I was out drinking and today I had a hangover and worked on my car as a penance. I glued the passenger's side wheel arch in place. It was actually more work than I expected. I had to use quite a lot of rivets to get the part to sit right. The result is not perfect but quite good. If I was to do the same job now I would replace the whole rear quarters. It would be less work and give a better result.
Slow progress with the car a bit more with the wheels but you could count it here because that will be munnies for the car project.
I painted the inside of the drivers side wheel arch so next time at the garage I'll be able to glue that one.
I also took apart the brake calipers and cleaned them with a wire wheel to make sure there's no paint left. I didn't bother to remove all the rust because it will be taken care of at the plating shop. I seem to have misplaced one carrier, though. Hope I'll be able to find it.
One of the pistons was pretty seized up. I tried different tricks for it. What helped in the end was I drilled some holes in the piston and put a steel bar through it. Then I clamped the caliper in vice, pressurized the cylinder with compressed air and started wiggling and turning the piston with the steel bar until it started slowly moving out and then popped free.
The brake calipers will be yellow zinc-chromate plated as well as the bolts for the RC:s. The bolts initially looked like the left one in this pic.
First I soaked the bolts and nuts in paint stripper to get rid of the thread locker and any remaining lacquer. Next I treated them with citric acid solution.
Then I rinsed them, dried them in oven and gave them a light coat of oil to avoid further rusting.
I gave the bolt heads a quick puff with cotton wheel and polishing wax to make sure they are presentable. Hope the shine wont be ruined in the plating process.
That took about a week at work doing 20 or 30 bolts a day at lunch break.
The wheel lips are mostly sanded up to 2000 grit using my ghetto wheel polisher:
I still need to roughen up and paint the backsides before polishing the lips. So what kind what kind of idiot has the patience and stupidity for this kind of stuff you may ask? This kind:
Driver's side wheel arch is now glued in place. With the experience from the passenger's side it went a lot smoother. Now I'm down to two major body parts: the rear face and the cross member for diff mounting but those will be left for august because on tuesday I'm leaving for a two-week trip to North America to represent our small country in the wonderful sport of roller derby.
__________________Last edited by Skarpa; 08-08-2017, 11:54 PM.Comment
Actually I'm going to sell the RC:s. I built 16" RS:s for this car. You can find them in posts #14 and #15. But thanks for the tip, I'll be following your build with interest.Comment
Rs will be worth more than rc's in the long run, good decision, my rc's landed in front of me & cant wait to run them. I still have a ton of parts to collect & start building the m52 but it includes a 24lb injector s50 chip tuned ecu.
Sent from my iPhone using Tapatalk1986 LTW M52 (First project 2015- )
1998 e36 328ic/5 -
Roundie alpina pig cheek’d (1969)
1967 2002 parts car
1994 318iS junked.Comment
