Yesterday I started learning metal turning. As so many times before in this project, my previous experience on the subject was zero. One of my goals with this project is to learn new skills. I made aluminum reinforcement cups for the transmission mounts. In E30 the engine will be so close to the radiator that I wanted to minimize the movement of the engine to avoid collisions. I know that these cups are available commercially but no one sells them in Finland and I wanted to learn to use lathe anyway.
I started with 60mm round aluminum bar stock and E21 transmission mounts.
The lathe is a small unit that my boss bought for a cheap price from auction a long time ago. He did some testing but came to conclusion that the lathe doesn't work properly and doesn't produce good quality so no one's used it since. I did some testing and adjusting myself and was able to produce satisfying quality. I think the tool holder might have been replaced at some point. Many of the tools seem to sit too high and may not cut properly. So I watched some educational videos and asked for a few tips from my workmates and felt confident enough to start. The lathe has such small chuck that I didn't want to put too long piece in it so I made the cups one by one. Slowly I progressed learning step by step.
For some reason I couldn't get the parting tool to cut properly. No matter how much I adjusted the tool or how much I used cutting fluid, the result was always the same. The tool started to vibrate and then cut too much all of a sudden. I ended up cutting the piece with an angle grinder and then finishing it in lathe.
I'm really happy with the result and the second one turned out twice as good in quarter of the time.
