Ooh, I started a poll :D
I haven't had time to spend at the garage but I've been tinkering with several projects related to Armo. One of them is the oil temperature gauge. A while ago I decided to replace the momentary fuel consumption gauge (the most useless gauge ever) with an oil temperature gauge. I studied the gauge and found out that it's not possible to control it with a simple voltage signal necause there are two coils for controlling the needle movement and they need to be powered in correct relation for desired needle movement. I bought an Arduino Uno to control the gauge.
While waiting for that I drew the gauge face in cad and had it printed on matte vinyl sticker which was glued on a piece of laser cut plastic sheet.
I had stickers made with two different shades of glue layer so I can test which one produces the best back light colour and brightness.
Darker, grayish brown glue layer gave a better result. The original gauge face has additional shading on the right side where the back light bulb is closest. It seemed to be necessary so I glued an additional piece of sticker behind the gauge face. That gave pretty equal illumination.
Next I needed to find out what kind of voltages the instrument cluster uses to control the needle movements. I coded a simple square wave generator on Arduino and used that to connect the speedo sensor wires via a photo isolator relay. However, the relay was not ablee to produce signal for road speeds over 60 km/h. I'll need to get a more suitable component for testing.
Once I have the control figured out I'll share the Arduino program as well as the files for the gauge face.
