I continued taking apart the M52. The piston rings and ring landings seemed to be ok. Not that that matters so much anymore.
When removing the crankshaft I had to stop and curse for a moment. The rear main seal cover didn't have room to come off the crankshaft and the crankshaft couldn't come off with it.
Luckily just loosening up the engine stand attachment bolts was enough to create adequate space. The crankhaft seems to be allright and will be sold to someone in need.
Then I had a good look at the M54B30 rotating assembly. I've had it for years waiting on the shelf. The crankshaft seems to be pristine. The bearing journals might be polished. I can't remember any more. With the measuring tools at hand the journals seem to be in standard size and round. The previous owner has cleaned up three pistons but three of them had a pretty thick layer of carbon deposit. I scraped it off. The pistons, wrist pins and con rods seem to be alright in my eyes. I'll send them to an engine shop for more throughout cleaning, inspection and to have the topmost ring grooves widened for M52 nikasil block piston rings.
The picture is taken with a potato I found at the bottom of the fridge. It had already started to sprout which is probably the cause for the lousy picture quality. The crankshaft was missing the trigger ring. I bought one as well as a crankshaft position sensor to take measurements for drilling and milling the sensor position in the block. My block has a placement for the sensor in casting but it hasn't been machined. M52TU/M54 crankshaft sensor is more reliable than the M52 one and allows me to use a vibration damper without the trigger ring. I'll most likely use a new M54B30 damper. Ati super damper might be cool but with the shipping to Finland the cost is astronomical. After all, dampers are wearing parts and most of the failures I've seen have happened when 10+ year old engines with original dampers have been punished hard.
Lately I've tried to come up with comprehensive shopping list with everything I still need to purchase for the car, all the way down to the seals, screws, bolts, grommets and small plastic fixings. As a part of that project I had a look at the A/C lines and drew myself a diagram of the hardlines and hoses. All the hoses will of course be replaced. I'll probably reuse the hardlines and paint (or zinc plate) them. The evaporator, drier, condenser, expansion valve and pressure switch will be new. I'll use the Nissens 94958 generic condenser since it seems to be impossible to find a car-specific parallel flow condenser for E30 in Europe. Because of the generic nature of the condenser I may need to modify the car front frame a bit to accommodate the connections.
