I started mounting stuff in engine compartment and building brackets for them. I started with AC condenser. No need to build anything there.
Next I mounted the radiator. It is a E36 328 A/C model. If I had a facelift car, it would fit right in the original mounts. As I have prefacelift I bought the 318is top mount and E36 bottom mounts and will build brackets for them. Turns out the E36 mounts did not fit without modifying I don't know why I didn't get the E30 ones but nevermind about that. I cut off the unnecessary part of the mounts.
Then I built shelves for the mounts. My vise came with the house. House is built in 1957 but I think the vise is probably older.
For motor cooling I've been thinking on electric fan. It will be easier to fit in the engine bay and reduces moving mass. I was just wondering if there's any sense in having two electric fans since there's already one for the A/C. I just need to think about the control. A/C fan runs 2-speed. It's on low speed whenever the A/C is turned on and on high speed when a sensor in A/C system gives signal. The engine cooling fan should be run by engine coolant temperature switch. If I use a single fan I need to allow both the A/C and the coolant temperature to switch it on. Anyone have experience on that? The A/C fan might not be enough to cool down the whole engine even though the same fan is used on M3 as the only fan (don't know about M3 with A/C though) I may need to switch into more powerful one. Of course I need to take care that the airflow will go through the radiator and not around it.
