Porsche Grey 24v 318is
  • mistacarder
    • Jan 2013
    • 289
    #46
    front
    rear
    i really want bags!!!!
    Instagram: @mistacarder
    • grinchxvx
      • Dec 2015
      • 295
      #47
      Where did you get that harness cover that goes on the cowl from? I recently snagged a m52 and I'm gathering parts. Sick car btw. funny that I stumbled upon this right, I'm painting my car a very similar color.
      • jeenyus
        • Aug 2011
        • 2064
        #48
        damn that oil pan sits so low.
        • badwella
          • 357
          #49
          That's the M3 wiring cover.
          P.O.S 1989 325is - aka Project Sh*tbox
          Project Shitbox - Restomod and other stuff - soon to be 328is
          • MT325is
            • May 2012
            • 1103
            #50
            color is on point! Love what you have done with the car!
            whats the color code? cuz thats the color I'm going after..
            Love the build tho!
            1989 BMW 325is (SOLD)
            1992 BMW 325IC (SOLD)
            1991 BMW 318IS (STOLEN!)
            2017 BMW M2 (WEEKEND WARRIOR)
            1989 BMW 325IC (PROJECT(
            2002 FORD ESCAPE (DAILY)
            • Dj Buttchug
              • Jun 2010
              • 7688
              #51
              I think the code is actually slate grey. 6601
              Turbo M42 Build Thread :Here
              Ig:ryno_pzk
              I like the tuna here.
              Originally posted by lambo
              • Brad Sindoni
                • Nov 2014
                • 178
                #52
                this is turning out beautiful. can't wait to see more!
                _keepitgutter
                88 Alpine white Super Eta
                • mistacarder
                  • Jan 2013
                  • 289
                  #53
                  Thanks man!
                  • mistacarder
                    • Jan 2013
                    • 289
                    #54
                    So some good news happened yesterday! Bagriders was offering sponsorships to ten different cars, and my car was picked. Another e30 was picked before, but he couldn't accept the sponsorship, so I was offered the spot. (THANKS CHRISTIAN CRBR30) Looks like I may be bagged sooner than later:) I am looking forward to doing business with Bagriders!
                    • TroyShark
                      • Oct 2012
                      • 195
                      #55
                      Lucky you. Do you get a choice of management?
                      • mistacarder
                        • Jan 2013
                        • 289
                        #56
                        V2 management with airlift at all four corners
                        • mistacarder
                          • Jan 2013
                          • 289
                          #57
                          So a little update on the build... I learned something new that almost cost me a lot of money! The car started running shitty, and wouldn't start. Then I finally got it started which resulted in backfires from the intake. I pulled off the VC and did a compression test. results were about 60 on all cylinders except #4 which had nearly no compression. After some inspecting I noticed the sprocket on the exhaust cam had loose bolts
                          Set the timing on the cams and retorqued the sprocket. did a new 3 crank compression test which resulted in 150 on all five cylinders except #4 which was dead:( Intake valves are bent on cyl 4 so I took the head off and I am waiting on new valves.
                          After doing some reading I realized you need to apply loctite to those bolts. It sucks, but everyone has to learn sometime. Luckily a bolt didn't come out!
                          • mistacarder
                            • Jan 2013
                            • 289
                            #58
                            so i got the head off and of course it bent two intake valves on cyl 4
                            my Hg came in the mail but it was bent thanks to ups
                            it was a victor reinz gasket, i heard many people have had problems with them so i might just get a mls gasket monday from achilles motorsports since they are local
                            • mistacarder
                              • Jan 2013
                              • 289
                              #59
                              So I got the head back on with a new gasket and the car is running GREAT!! I drove it on the road for the first time today and god I LOVE THIS CAR! I still need to get it aligned so I can drive it more... The only issue I have is the idle air motor under the intake comes on when the car is off and turns off when the car is on causing my battery to die... I have went through the wiring harness double checking everything and no luck. I have a red label 413 ecu and a silver label 413 with a chip... It does this with both computers so I am lost
                              I also made some seat rail covers to clean up the interior by hiding the recaro adapters
                              • JeLani
                                • Aug 2015
                                • 1552
                                #60
                                i like
                                1986 LTW M52 (First project 2015- )
                                1998 e36 328ic/5 -
                                Roundie alpina pig cheek’d (1969)
                                1967 2002 parts car
                                1994 318iS junked.
